    Oct 2006
    williamsburg,virginia
    Default engine will not crank
    2008 mobius lsv 325 indmar
    I installed a new battery, starter, fuel filter, fresh gas and tried to start my boat the first time in about 6 months and the engine would not turn over. I have power to the starter and the guages work except for the perfect pass. When I put the boat up last year I started to have problems with it starting but no problems with it cranking.
    Thanks
    newwave1
    Is your throttle in the neutral position?
    99 Outback LS. Sold
    Jun 2010
    Lake Houston
    Default Re: engine will not crank
    Starter won't engage or it turns over but won't catch?
    2013 LSV
    2005 LSV - SOLD
    Nashville, TN
    I had the same problem with my 98 outback. I had the starter rebuild, replaced the spark plugs and a couple other things and it ended up just being the ignition, where you turn the key to start it, replaced that ($10 at parts store) and started right up. Here is a video of what mine was sounding like. Hope this helps!
    http://www.youtube.com/watch?v=Kh9g_SOlMKU
    1998 Outback
    Oct 2006
    nothing happens to the starter brand new, same thing with old starter
    thanks
    newwave1
    Oct 2006
    yes throttle is in neutral
    thanks
    newwave1
    Oct 2006
    I'm getting power to the starter, but it will not crank
    thanks
    newwave1
    Jun 2010
    Lake Houston
    Edit my bad didn't realize that video wasn't your boat. So the way you can tell if its the starter or the ignition switch is to jump the solenod with a screwdriver. If the engine cranks its your ignition switch if not, starter/solenoid.
    2013 LSV
    2005 LSV - SOLD
    kill cord with the red leash hooked up correctly ?
    Oct 2006
    thanks, I'll try that.
    newwave1
