Results 11 to 17 of 17
    NOR-CAL
    I had removed the set screw it was just on there for so long I think it was a pain to get off.......But I got it!!!!!
    After pulling the V drive there is a bunch of room...lol
    Made my own gasket with a roll of material....it is a little bit thicker but that shouldn't be an issue....RIGHT???
    My shaft and v drive plate are about 1/4 of an inch offset to the left so I am going to try and realign my engine.....Did I ever mention I'm not a mechanic....lol
    07 LSV usually DUMPED
    Quote Originally Posted by Hillbilly View Post
    I think you qualify as one now.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Jul 2009
    Spokane, WA
    How bad is pulling the v-drive on these things? I looked at doing that a few years back to replace the strut bushings, but ended up pulling the shaft out of the back of the boat. No issues really, just a bit of a pain with such tight quarters to work in.
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
    A dealer mechanic told me once it's easier to pull the v-drive than to loosen everything to get it out the back past the rudder. I had to loosen my strut to get enough clearance to slide it out the back.
    Jul 2009
    Spokane, WA
    Kane, did you have to re-align your strut after you loosened it? When I pulled my prop shaft, I debated whether or not to loosen the strut. I was really hesitant and didn't end up having to in the end.
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
    Jul 2011
    Murrieta, CA
    Default Prop shaft coupler bolt????
    If the strut is loosened it is likely to have move enough to warrant an alignment.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    I don't know how to re-align a strut. But, after I put mine back tight I had to re-align the engine. But that was after a shaft replacement and you'd have to do it anyway. Nice n straight now.
