Results 1 to 10 of 17
    NOR-CAL
    Default Prop shaft coupler bolt????
    I spent a good couple hours trying to get my prop shaft coupler bolt out and could not get it to loosen?
    I was cranking on it both directions and al it was doing was torquing the shaft....When I pushed the shaft back up to put a couple bolts in to hold it now the coupler and tranny plate are about 1/4 inch offset....Did I bend my prop shaft trying to get the nut off?
    I backed out the set screw but could not get the bolt to loosen....Is it a reverse rotation nut? Think its a bad idea to hit it with an air ratchet?
    I'm replacing my dripless packing seal that was a steady stream. Think it could have gotten hot enough to "stick" the nut and coupler/shaft together.......HELP
    Thanks guys
    Hillbilly
    07 LSV usually DUMPED
    Jul 2011
    Murrieta, CA
    I was not able to separate the shaft and coupler in the boat.
    I took out the entire shaft and took it to Elbert's (marine shaft shop). He got it loose in about a minute.
    If you think your shaft is bent get it checked before you reattach.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    I'm not sure how you would get it out with the coupler attached. I slid mine out the bottom after removing the coupler. I just can't remember how I held the shaft when I did it. Probably put a bolt back in and held it with a wrench on the bolt or something.
    Jul 2011
    Murrieta, CA
    I had to pull the v-drive to remove the shaft assembly. It was much easier than fighting the shaft in place for me.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
    NOR-CAL
    I'm going to turn the shaft and see if the offset changes any as I turn the shaft and that should tell me right away if it's bent......Maybe it is out of alignment and that is what caused my seal to fail?
    It was creeping up on midnight and after knuckle busting it for a few hours I packed it in for the night.
    Maybe the bolt and shaft are seized together? If so any tips on freeing them? Heat or Ice!!!!!!
    Thanks....
    Sep 2005
    Claytor Lake, VA
    Used this procedure when I installed my dripless seal and it worked great.
    https://forum.moomba.com/showthread....removing+shaft
    2005 Mobius LSV
    NOR-CAL
    I got the nut off this evening then decided to pack it in for the night .......A few more steps and I will be 1/2 way done......lol
    NOR-CAL
    SUNOFABISCUIT.......Ended up pulling the v-drive......Now does anybody happen to know a model # for a new gasket??? LOL
    This quickie job I thought I was going to do has turned into a huge fiasco!!!!!!
    Going to hit up WestMarine Mon or Tues....I'm going to try and find a deeper nut for the coupler that thing is really shallow and got a bit worked over........
    Jul 2011
    Murrieta, CA
    If the strut is loosened it is likely to have move enough to warrant an alignment.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
    I don't know how to re-align a strut. But, after I put mine back tight I had to re-align the engine. But that was after a shaft replacement and you'd have to do it anyway. Nice n straight now.
