Results 11 to 20 of 26
  1. #11
    Lake Amistad, TX
    Default 08 LSV Mods w/ links to everything
    Quote Originally Posted by jstenger View Post
    Tgoody - Contacted Monster, and they were no help. I see that the forks mount to an oval bar. Is that bar the same size and dimension of the oval crossbar on your tower? I was thinking about buying the racks just for the forks.
    Sent from my Droid Charge using Tapatalk 2
    At first I didn't understand what you meant, but yes if you didn't want the swivel attachment you should be able to just mount the Black Monster Racks to the oval part of your Moomba Tower. I will go over to the storage tonight and measure both oval bars and see if they are the same size!
    Either way it's not going to be such a big difference that you couldn't shim them to fit...
    2008 LSV Blue on White
  2. #12
    Lake Amistad, TX
    I just realized I uploaded 2 of the same pics on the bracing of the v-drive lockers, instead of showing the actual braces... Oops haha
    Here's the correct pics
    http://i224.photobucket.com/albums/d...psc660e53d.jpg
    http://i224.photobucket.com/albums/d...ps78627ace.jpg
    Thanks JPetty for the heads up!
  3. #13
    Belton, Texas
    2009 Moomba Mobius LSV
  4. #14
    Arkansas
    Nice work! and great write up.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  5. #15
    Lake Amistad, TX
    I measured the oval bars and they are exactly the same! Should work perfect for ya, just remember those racks are for a wakeboard and a thicker style surfboard! I'm looking at some rubber tubing to slide over the top fork to fill the gap until I find a thicker surf board! 😁
    KG - Thanks
  6. #16
    Jul 2010
    Vicksburg, MI
    Default Re: 08 LSV Mods w/ links to everything
    Cool. Thanks for doing that.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
  7. #17
    Quote Originally Posted by tgoody14 View Post
    I'm looking at some rubber tubing to slide over the top fork to fill the gap until I find a thicker surf board! ��
    KG - Thanks
    In a pinch those pool noodle things with a hole through the middle will work temporarily and there are different thicknesses. Only cost a couple bucks.
  8. #18
    Lake Amistad, TX
    Jstenger - no prob man
    Berg - I like your style! I just happen to have a spare PINK noodle that would go great right there! Thanks for the quick fix! Should work perfect while the search still continues for another board!
  9. #19
    Lake Amistad, TX
    Got my Acme 1617 prop in yesterday and had some time after work today to put it on!!
    Here's a very informative write up for Props:
    https://forum.moomba.com/showthread.php?t=15139
    You don't really need any tools other than a wrench, pliers, and a portable torch to heat up the area where the shaft meets the prop (slides right off)!
    Careful when you go to loosening up that nut tho... I was given 'er hell, then she quickly busted loose, slamming my knuckle right into the prop!!!! SONNN OF A.... I almost cried 😭
    http://i224.photobucket.com/albums/d...psab49523e.jpg
    http://i224.photobucket.com/albums/d...ps933aba40.jpg
  10. #20
    I love the way a new prop shines!
    Sent from my iPhone
