Results 1 to 10 of 10
    Nov 2009
    Nebraska
    Default Rear ballast bag connection
    Filling up for surfing and my ballast came loose spilling water everywhere. Notice that the quick connect elbow that a piece was busted off. So I need one of these
    http://www.wakemakers.com/fly-high-p...ting-w746.html
    Now I noticed to install that I need this
    http://www.wakemakers.com/pinch-hose-clamp.html
    My question is what size will I need and do I really need the tool
    2016 Mojo
    2010 Moomba LSV-Sold
    Feb 2010
    Canton, Ga / Lake Lanier
    Why don't you just get a hoseclamp from Lowes? I just did my hole project with those. Sure the crimp ones look nicer but are a PITA to remove if you ever need to.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Saugus, Mass
    I second the hose clamps. Quick and easy to disconnect for whatever reason later.
    Aug 2011
    Default Re: Rear ballast bag connection
    Zip ties.. Easier..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Lake Amistad, TX
    Is this a common problem!?!? I just installed 2 1100lb bags in the back and I didn't even think about something like that happening... that would not be fun!!
    2008 LSV Blue on White
    Nov 2009
    Nebraska
    Mine happens every once in a while, I also noticed the back panel of the ballast location has had two screws loose, don't no if this was causing it
    2016 Mojo
    Nov 2009
    Nebraska
    Like this one
    http://www.wakemakers.com/stainless-hose-clamp.html
    2016 Mojo
    Feb 2010
    Quote Originally Posted by snyderaaron View Post
    Yep...that exact one. I think I paid $4.99 for a pack of 10.
    Tow Rig:
    Second lowes or Home Depot for the the ss clamps, bought lst of them for my upgrades, use black electrical tape around the bags.
    fittings try this
    https://www.flow-rite.com/product/ma-049
    Sep 2005
    Claytor Lake, VA
    I used the pinch clamps around the bags and regular hose clamps everywhere else. Old end nippers make a good tool for pinch clamps. I like the zip tie idea.
    2005 Mobius LSV
