Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Feb 2010
    Canton, Ga / Lake Lanier
    A few PMs but nothing serious yet...hmmm how about $300 shipped for end of season special?!
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  2. #12
    Jun 2013
    Oxford, MI
    So tempting...
  3. #13
    Feb 2010
    DO IT Wax!!!
    Tow Rig:
  4. #14
    Jun 2013
    Oxford, MI
    In process of buying a house on our lake right now...that's the only reason why I'm hesitant. they scrutinize everything, and so will my wife! Supposed to close mid October. Maybe then...
  5. #15
    Sep 2009
    Langdon ND
    Will this prop give you any more top end and still give you good bottom end pulling. I have a 2006 lsv with stock prop and cant remember which numbers are on it, problem is not quite having enough speed for my son to barefoot decently with out so much spray from his feet as boat with him behind will only run 35 mph and is only turning about 4500 rpms. Wondering if this will make motor turn more rs to get more speed. When wakeboarding with 1200 lbs and 4-5 people in the boat a little bid of a dog to get on plane, would like something with better bottom and top, maybe not possible?
  6. #16
    Feb 2010
    Default Acme 537 For Sale
    We have no problem getting up and out with that sort of weight when we are skating. I use my boat primarily for surfing about 2400 surf side. It does ok but with that much weight I think the boat works a little harder than it needs to that's why I'm looking to change. I know it has trouble getting up and out if you had the floor full and 750s in each rear. We tried that last year and it took a while to get on plane.
    Top speed with this prop is 42 I think. I'm not sure of the RPMs though. I don't think I've seen it over 3500 very often during normal use (surfing, skating, boarding). I may be wrong though...if you run it at 40+ I'd imagine the RPMs would be higher. We rarely go faster than 30...we have no need to.
    Tow Rig:
  7. #17
    Sep 2009
    Langdon ND
    Im thinking I have to tall of prop as empty of ballast and one person in the boat the motor wont pull over 4600 rpm and 36mph. If I had a prop that would let the motor pull more R's would I be better off all around?
  8. #18
    Feb 2010
    You should probably call Nettles or Wakeprops.com and they can give you the detail on what might be and if this would be best for how you use it. Unfortunately O just don't know enough.
    Tow Rig:
