Results 1 to 3 of 3
Thread: Prop ?
    Mar 2013
    Default Prop ?
    What are some pros and cons of my prop 13x11.5 acme 3 blade.What kind of rpm range to stay in and top speeds for this setup,Iam new to these kind of setups just trying to gain some info.
    2013 LSV
    2006 outback DD sold
    2004 Stingray 180LX sold
    The "standard" prop for years was an 13 x 13. It would allow a max RPM of 5,000 and top end around 42 mph (with some variation depending on weight and trim). You should have a little more hole shot and a little less top end. You might achieve a slightly higher RPM at WOT. I think your boat is supposed to max at 5,000 RPM. You can check your RPM and MPH at WOT and see what you get.
    Pensacola, FL
    Contact OJ Props or Acme Props. Their reps are very good at telling the benefits of various props, especially for a DD boat that has been around for a while.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
