Results 1 to 6 of 6
Thread: Vibration
    Mar 2013
    Default Vibration
    I just recently purchased my first direct drive boat (06 moomba outback),my question is what would cause a vibration and noise in the steering console area. I looked and could not feel anything loose,thanks
    2013 LSV
    2006 outback DD sold
    2004 Stingray 180LX sold
    Pensacola, FL
    When does it do it? At speed, all of the time??? What noise, popping, cracking, etc: More info is needed.
    Could be an issue with the prop, could be a rudder box, could be a steering box. Hard to say with limited info.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Mar 2013
    More rattling at speeds, it stops sometimes depending on where the steering wheel is turned, it seems like it might be in the steering, but it steers fine and I cannot find anything loose, but it seems to be coming through the steering into the console, if that makes any since
    2013 LSV
    Flowery Branch Georgia
    Have the prop checked . You probably have one of the blades bent.
    You may have to grease your rudder linkage. On my Outback I could pull the cover plate and put grease in the zerk right at the top (side) of the rudder. It would smooth everything out.
    Nov 2009
    Gatineau, Quebec
    my outback did that especially when accelerating from a tern, seemed to do it only when rudder was turned when power is applied .Greasing ruder will remove most of the vibes going to the steering wheel you may want to check your rudder bushings while your there.
    2012 Mobius LSV
    05 Outback LS SOLD
