Thread: Tower Bimini Brackets
01-03-2006, 03:55 PM #1Member
- May 2005
- 62
Has anyone had problems with the plastic pieces on the bimini breaking?
First the plastic piece broke off the end of the bimini. After I fixed that the plasic piece on the the tower that holds the bimini broke. The Bimini must not be fitting correctly which is causing a lot of tension on these brackets. Wondering if other people have the same problem and how they got around it.
It looks like the 06 models use a bracket that goes around the tower to hold the bimini. Does this seem to work well on the 06s? Maybe I can order one of these tower brackets to go on the older tower (03).
01-04-2006, 01:23 PM #2Senior Member
- Oct 2005
- Central FL
- 791
Replying to Topic 'Tower Bimini Brackets'
You can replace the plastic with Stainless hardware. Much stronger.
www.cabelas.com
Joe
01-04-2006, 02:24 PM #3
I broke the plastic ones on my old run-a-bout a few years back. But, being employed in a machine shop, I was able to fabricate a couple new ones out of aluminum. I see the old ride every once in a while. The brackets are still in service and still look good. But I would have to agree with Ed. Much eaiser to replace plastic. Those things can't be more than a few bucks apiece.
Hope this helps
01-05-2006, 04:10 AM #4Senior Member
- Oct 2005
- Central FL
- 791
Ed,
I'm not quite sure what you do to your Bimini bud.
I've had 3 boats, and grown up w/ many family boats and all had Stainless hardware and none ever popped a single screw through the gel coat. I've run in pretty rough pounding surf in the gulfstream, and have people hanging on the back bow sometimes to keep their balance... still never cracked, broken or damaged anything.
Plastic (actually nylon in this case I believe) sucks. Plain and simple.
If the particular install is taking a beating side to side, then they sell hinge mounts that flex... yes, they have them in SS.
I also think this is a tower mount so no glass involved.
-Joe
Tower Mounted Bimini
By K_E_N in forum General ChatReplies: 2Last Post: 04-08-2008, 10:13 PM -
Z-Cargo tower rack bimini
By moomba_armada in forum General ChatReplies: 0Last Post: 02-11-2007, 07:05 AM -
WANTED: Bimini for 2001 Outback (no tower)
By schlepper in forum Moomba ClassifiedsReplies: 2Last Post: 05-17-2006, 09:55 AM -
XLV Tower Speakers / Lights with Bimini
By dazo in forum Boat OwnersReplies: 1Last Post: 10-21-2005, 02:07 PM -
Speaker tower brackets for Moomba
By Lance in CA in forum Moomba ClassifiedsReplies: 3Last Post: 04-22-2004, 10:29 AM
