Results 1 to 10 of 17
Thread: shaft strut
    Irondequoit Bay, NY
    Default shaft strut
    so most of yall know last summer i hit a sunken tree in the bay, im looking to see if anyone knows a good site to pick up a 15 degree strut for my shaft. i know i can probably get it at my dealer but i want to look around and see if i can get it cheaper since half the time the dealers have the higher price
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Default Re: shaft strut
    I think kaneboats got his here and was very pleased
    http://www.elberts.com/
    Had to buy longer bolts due to flange thickness
    That's where I got my shaft. Don't know if they have struts. I'd go with Skidim or at least start there. Are you sure it's a 15 and not a 14 or 16?
    http://www.skidim.com/products.asp?dept=1124
    Irondequoit Bay, NY
    it says 15 then under that SEF1951L..i wonder what would be better for wakeboarding
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Jul 2011
    Murrieta, CA
    Default shaft strut
    I bought a replacement strut from Elbert's after an encounter with a dead head at 8hrs on the boat.
    The mounting surface is thicker but my bolts were just long enough....
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Irondequoit Bay, NY
    ill take a look..anyone know if a different degree strut will help with my wake to be bigger?
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Quote Originally Posted by motosno963 View Post
    i think it could lead to alignment issues when trying to bolt the shaft onto the transmission coupler
    2017 Moomba Mojo Max Surf Edition, 2 Pair Wetsounds Rev10s powered by an SD2, 6 paid Wetsounds XS650M and Wetsounds WS12 powered by SD6 all controlled by a WS420.
    Dec 2006
    Tuscaloosa, Alabama
    I agree with alignment issues
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Portland Oregon
    Default shaft strut
    Elbert has saved me some coin over the years as I learned my way around the Willamette River finding rocks, funny you guys know about him!
    -Jake
    Irondequoit Bay, NY
    so your saying i should just stay with the 15 then?
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
