Results 1 to 10 of 13
    Jul 2010
    Vicksburg, MI
    Default OBV Swivel Seat Mod (Very Popular Lately)
    I took a similar approach to the others with a few changes.
    Parts:
    (2) 9" X 13" X 1/4" Aluminum Plates
    (1) Swivel
    (4) 1/4" - 20 X 3/4" Bolts
    (16) 1/4" Washers
    (Eight) 1/4" Locknuts
    (Eight) 5/16" - 18 X 1" Bolts
    (2) 5/16" - 18 X 2 1/2" Bolts
    (4) Factory Flange Nuts (Originally held seat to rails)
    (12) 5/16" Washers
    (4) 5/16" Nuts
    (2) 3/8" Nuts
    (2) 3/4" X 1 5/8 Aluminum Spacers
    My factry seat did not have holes in the center to attach the swivel to, so I mounted one of the plates to the bottom of the seat using 5/16" -18 X 1" bolts, washers, and factory flange nuts.
    I then drilled thru the plate into the seat. The seat was hollow in that area, so I drilled the top out to 3/4" so that a socket would fit in to hold the nut.
    I set the other plate on top of the rails and shimmed up to make the plate even with the floor. The angle worked out to be 6 degrees.
    I set my adjustable square to 6 degrees and mounted it to my surface grinder.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    Jul 2010
    Vicksburg, MI
    Here was the fun part. I had to grind a 6 degree angle on the 5/16" nuts, 3/8" nuts, and 3/4" spacers. Only grind a little so as to just make an angled flat spot on each. A spare long bolt was used to hold the nuts while grinding.
    I mounted the swivel to the bottom plate with the 1/4" - 20 X 3/4" bolts, washers, and locknuts. I offset it 3/4" to get the center of the seat inline with the center of the steering wheel.
    I then mounted the assembly to the rails with the 5/16" hardware. You can see the 3/8" nuts used as spacers on the left, and the 3/4" spacers on the right. The grinded surfaces go down. The 5/16" nuts that were ground are inside the rails, and cannot be seen in the pic. The grinded surfaces on those go up. All the grinds were necessary so that the nuts would pull flat against the rails and not bend the bolts.
    Joe
    2014 LSV
    1993 Echelon
    Nice work. I just slapped the ole angle iron in there to boost it up to level. Gonna work great.
    Jul 2010
    Vicksburg, MI
    Here is the seat mounted. It rotates 180 degrees.
    Joe
    2014 LSV
    1993 Echelon
    Default Re: OBV Swivel Seat Mod (Very Popular Lately)
    Nicely done!
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Oct 2005
    Durham, NC
    Wow, very thourough, and well done. Doesn't the seat sit more upright now though?
    Brian Roberts
    2001 Outback DD
    Jul 2010
    Vicksburg, MI
    Yes, the seat is more upright. I made the swivel flat with the floor, and that was the result. If I didn't, it would lean way forward when facing backward. I plan to try it out this weekend. If I don't like it, I am going to raise the front of the seat above the swivel. That way the swivel will stay flat and the seat will be tilted back like the stock position no matter which way it is facing.
    Sent from my Droid Charge using Tapatalk 2
    Joe
    2014 LSV
    1993 Echelon
    Irondequoit Bay, NY
    i like..i wanna do this on the outback
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Jul 2010
    Vicksburg, MI
    UPDATE:
    So after driving the boat for awhile, I decided that I was not happy with the upright seat position. I bought some composite shims from Menards. Each shim is 1.5 degrees, so four shims superglued together gave me the 6 degree angle that I needed to lean back the seat to the stock angle. I made two of these shim blocks and placed them between the swivel and the aluminum plate on the bottom of the seat.
    To clear the throttle, because the back of the seat is now farther back, I drilled new holes in the aluminum plate to move the base an inch and a half forward. You can see in the above pic that the upper and lower aluminum plates are now offset an inch and a half from front to back. Below you can see the angle of the seat, and how it matches up the rear seats.
    The seat is now very comfortable no mater which way it is facing.
    Joe
    2014 LSV
    1993 Echelon
    Looks more comfy now. Nice work!
