Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Default Fat sac gurus come here
    Right now I'm only having one fat sac in the locker in the middle of the boat. My concern is that I don't think that only 600 pounds is enough to make a great surfing wave.
    It will sink the boat but ...
    But we will always be around 3-5 people on the boat so should I worry or with the people sitting in the back it will be okay?
    If not this is my other option
    http://www.ebay.com/itm/FLY-HIGH-JUM...item45f1d60320
    But will it fit in the locker in the rear of the boat (Moomba mobius lsv 09)
    Thank you
    750 is probably better.unless you get an ibs to weight down the bow(650lbs)the Lsv needs bow weight with a 1100 in the rear locker.
    check out wakemakers.com
    Quote Originally Posted by wakeboy View Post
    if this is your goal, you need 1,100's in the rear lockers linked to 370's under the seats (cut out the cooler on the port side) and add the IBS.
    Ok so it means even if I have a 600 pounds in the middle ill need a 650 pounds bow in the front and a 1100 pounds in the back
    My plan was to keep my 600 in the middle and add 1100 in the rear
    You got it.
    You got it.
    Thank you so wakemakers is gonna rip my wallet again
    So the 1100 is fitting in my rear locker (lsv 09) ?
    Yep, same prices as eBay reseller. Might give you a break if you call Jason or spencer.
    I'll give a shot tomorrow
