Results 1 to 9 of 9
    Lake Amistad, TX
    Default WTB: 2 750s and 1 1100
    Thought I would check with you guys before putting in my order through wakemakers... I'm looking for 2 750 sacs for the back and an 1100 sac to swap out the 750 on surf side when surfing. If any of you guys have these spare bags laying around let me know, I'd be happy to put them to use....
    Also, do you guys find it necessary to purchase that extension tube when you swap out the factory sacs for the 750s in the rear on the LSV????
    Thanks,
    Taylor
    2008 LSV Blue on White
    I'd suggest 2 1100's and just don't fill them all the way full. Swapping bags is a pain depending on how often you do it and for ~$40 more each it's one-and-done. You're still money ahead only buying 2 that way.
    Lake Amistad, TX
    Now why didn't I think of that... 😧
    Thank ya Berg!
    Quote Originally Posted by tgoody14 View Post
    Thanks,
    Taylor
    What extension tube?
    Lake Amistad, TX
    Mike,
    It's a lil combo pack they have by boat brands. You pick the size bag you want and it comes with an extension hose to attach to the factory hoses in the back...
    http://www.wakemakers.com/supra-and-...r-upgrade.html
    Sep 2008
    Port Byron, IL
    The 750's are plug and play on the LSV and likely any model. (The same 750's worked on my LSV and Mojo). I am not sure about the 1100's. Someone with 1100's might be able to chime in. I think the 1100's have a center fill/drain/vent that the stock line wont reach unless you pull a few mounting clamps.
    "The Boomba" '12 Mojo 345HP
    Tow Rig: '08 Duramax
    Lake Amistad, TX
    Yea I'll prolly be going with 2 1,100 bags so I may need that extension, surely somebody here has done this...
    Apr 2012
    Bunker Hill, IL
    I know on my supra 21v you need to extend the lines with their tubes or you have to get some lines and couplings. Mine would not reach. (i went from 400 lb's to 750 lb's)
    2007 supra 21v
    Yes you will need them will the pre 09 systems.
