Results 1 to 10 of 13
Thread: Removing Decals
    Apr 2012
    Indiana
    Default Removing Decals
    So Im upgrading my decals next week and need to remove the old ones. Anyone have any advice?
    05 Moomba LSV
    Oct 2005
    Durham, NC
    Definitely use a heat gun or hair dryer to soften up the adhesive.
    Brian Roberts
    2001 Outback DD
    Quote Originally Posted by NCSUmoomba View Post
    times two, start with hair dryer, or heat gun on low.
    Jul 2011
    SE MI
    +3 hair dryer to get the decal off... then some acetate to clean off the sticky residue...
    2008 LSV 1100s 650IBS Reversible Pumps w\Timers
    Get some spray on goof off and be prepared to take some time to get all the sticky off. I used a hair dryer though and probably should have found a heat gun.
    Irondequoit Bay, NY
    i used a hair dryer and a plastic razor blade
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Mar 2008
    Vancouver WA
    Default Re: Removing Decals
    M.E.K. is a great solvent you can find in the paint section of any store. Works great on gel coat. Just remember to put a good coat of wax on after you clean the residue, but before you put the new decals on.
    Sent from my iPhone 5... ya right!
    PWI as usual...
    Lake Amistad, TX
    Depends on how much sun your boat has seen on the decals....
    My 08 LSV was on a slip year round since new and the drivers side saw the sunrise every morning, other side never unless out of the slip...
    I removed my decals couple weeks ago and the passenger side came off in one pull using a hair dryer and my fingernail. Took a total of 10 minutes, taking my time!!! I was excited!!! Went around to the drivers side.... 3 hours later I was only halfway done and my hands/fingers were toast!!! I sprayed goo gone on it and let it sit over night and finished it up the next day, which wasn't any easier... Just giving you a heads up if yours has seen a lot of sun!
    Also I read acetone will eat the gel coat in the long run so maybe steer clear of that and if you have a local car store you may go buy a 3M adhesive removal wheel that attaches to a cordless drill to make the job a little faster if you decals have seen a lot of sun!!!
    2008 LSV Blue on White
    Lake Amistad, TX
    Quote Originally Posted by redmondson View Post
    I just realized the original post was a month ago... 😤
    Soooooo how'd it go!? lol
    Yea, let's see some naked pics.
