Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Belton, Texas
    Default Big Goof Up......left brake cable hooked up and pulled out
    well I goofed up and somehow overlooked unhooking the emergency brake cable today when I put the boat up. I pulled fwd to close the door and ripped the hook off the cable as I pulled fwd. the cable is pulled our far enough that I can see some yellow paint on he cable. I had to run and grab my oldest daughter from church so I haven't had time to play with it except to push the trailer backwards and fwd a little bit. when I push it backwards I hear the metal on metal grinding sound.
    what kind of damage am I looking at and how much money can I expect to be out?
    sent from my home phone
    2009 Moomba Mobius LSV
    I can ask the dealer tomorrow but the emergency cable your refering to is designed so that it your boat unhooks from the truck it applies the trailer brakes. Its interesting you can move the boat at all LOL.
    Default Re: Big Goof Up......left brake cable hooked up and pulled out
    Pull the lever underneath to return the line and replace the hook.
    2006 Moomba Mobius LSV
    Belton, Texas
    What lever are you referring to parrot?
    Belton, Texas
    Maybe cause the boat wasn't in motion when it got pulled out?
    http://www.ufpnet.com/Portals/0/PDFs/Actuators.PDF
    If you pulled the hook off the brakes should be locked, if it's locked use the break cable release leaver to reset it. If not either the hook came off too easily, or you have another issue...
    Feb 2009
    Wausau, WI
    Let us know how this works out for you. I did a similar thing a year or two ago. During the unhooking process, I left the safety cable on the ball accidentally and then moved the truck forward. The only thing on the was safety cable. The cable broke/pulled cleanly off the trailer. I never look anymore into it, as everything still worked, no locked brakes, brakes still apply as normal.
    Matt
    Feb 2009
    Wausau, WI
    Quote Originally Posted by Hoopskier View Post
    For me, I guess I answered my own question regarding a broken cable. $20 from boatmate
    https://www.boatmateparts.com/produc....php?itmId=429
    Here is the owners manual, with the exploded view of the internals
    http://www.ufpnet.com/Portals/0/PDFs...aintenance.pdf
    Matt
    Belton, Texas
    ill play around with it after work today. thanks for the replies
    Mar 2009
    South Bend, IN
    I think when I did it....errr I mean, I have this friend that I know when he pulled his off completely it cost $125 to replace the whole thing. I was told I could link it back together, but I figured it wouldnt be as strong and just wanted it completely replaced....I meant my friend that I know wanted it replaced....LOL
    2009 Moomba XLV
