Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
  1. #31
    Jul 2011
    Murrieta, CA
    Default Bestia Surfing 2013 Mojo
    Looks like a perfect fit!
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  2. #32
    Got a new Enzo 1500 Sac in the other day and had to try it out. WOW this bag is HUGE. 102 inches long. Luckly thats exactly the length of my compartments on both sides muahahaha
    Wave was HUGE it was tall, long, i had to speed the boat up to 11.5 to 12mph to flatten the wave a little but it has a Ton of push. I didnt really take any pictures of just the wave, ill do that next time we are out.
    Wave was clean with 1/4 plate all the way to Full wake plate, boat had no issue coming out of the water with 2600 lbs.
    I ended up running a few hundred in the Goofy locker bag and the wave just gets better. Plus it helps lessen the lean angle a bit.
    this sounds like a rather similar setup somebody has been suggesting for the Mojo . . . .
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  3. #33
    Weight wise yes bro you have been saying these weights, but like i said i wanted to try everything, its my nature LOL Also i really needed to know it had to have 1500 in the rear to really make it good, those Enzo sacs arent cheap. Nearly 500 each on the site if i recall.
    Also i really wanted to make sure i could keep using my X link system on a 1 bag system.
    I honestly wanted the Gravity games 1180 to fit the bill, then i would have more room in the V lockers but its ok. We will have a lot of room in the boat, and im not one to carry anything not needed on the boat LOL.
  4. #34
    I would have done the same. Just busting stones.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  5. #35
    Is all good man is all good
  6. #36
    Dec 2012
    Ennis, TX
    Mike,
    In your experience with the Mojo what has been your absolute best wave setup. I have a decent wave I thought, until this past weekent I jumped on a buddys boat Nautique 210 Byerly Edition and was blown away by his surf wave. That boat is not supposed to produce a wave like that but it was so easy to stay in the pocket almost effortless. The wave had massave push. No way that boat should produce a better wave than the Mojo! What do we need to do to improve the Mojo wave??? Dont get me wrong, the mojo wave is decent but I know there has to be a combination to make it much better. I'm running Drew's setup plus I have a couple of the stock 400's to move around. So far the best wave has been with the additional 400 on surf side seat in the corner and the other 400 under the middle bow seat on the floor.That would be 1870lbs surf side around 400 starboard (might try all 750 this weekend to see if it would give it more push seeems like the nonsurfside weight is what is creating the push) up front IBS 550lbs plus hard tank plus the extra 400. Thats around 3770lbs of ballast only. Any more ideas?
    Shane
    2012 Mojo 2.5
    EXILED
    6 XM9 Tower
    6 SX65M Cabin
    1 XI 800.4
    1 XI 1500.1
    2 MX 30.2
    EXILE ZLD MKII
    EXILE Blue tooth EXBT4
    Green LEDs
  7. #37
    Mike & I are running basically the same setup. I'm using the 2 bags along the port side (1,100 & 370) and he is using the Enzo (1,500) bag. How was the Natique weighted? Did it have the NSS system?
    When it gets down to it, it all depends what your priorities are. How much did you want to spend on a boat? How big of a boat do you want? Do you want to have friends out and enjoy time on the boat or do you want to get the bast wave possible and train to win competitions?
    You want an incredible wave out of your Mojo?
    Throw a triangle sac on top of the bow seats
    http://www.wakemakers.com/straight-l...w-sac-650.html
    fill the floor
    http://www.wakemakers.com/straight-l...t-sac-800.html
    throw this across the back seats
    http://www.wakemakers.com/fly-high-fat-seat.html
    load the surf side locker up with lead
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  8. #38
    does your wave look like this?
    this setup is 1,100 in port locker, 370 under seat, 125 brick in port cabin corner, 500 in starboard locker, center full and IBS full. Wakeplate 100% up & 11.1 mph. Had a crew of myself driving, wife & 2 kids.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  9. #39
    Dec 2012
    Ennis, TX
    Yes very close. Maybe I need to try more weight starboard side. I am running your exact setup (pulled from your tread) I have a 750 starboard that I normally fill about half full. Mine is not quite as clean as that. Its hard to believe that is all they way up on the wakeplate. To get mine that long I need to have the wakeplate about 50%. It gets really steep at 100% and not nearly as long. What do you think I am doing wrong. Ah, maybe a speed issue. We generally run a 10 to 10.5 max any faster the boat seem to outrun the rider. That could also be a board issue. But, I would think the triple x could keep up though. I am a big guy at 6'2 240. Maybe i need to buy a few of the bricks and try different placement.
    Shane
    2012 Mojo 2.5
    EXILED
    6 XM9 Tower
    6 SX65M Cabin
    1 XI 800.4
    1 XI 1500.1
    2 MX 30.2
    EXILE ZLD MKII
    Green LEDs
  10. #40
    try increasing your speed and the wakeplate should be at least 75% up. You can try some longer fins in the board to provide more speed, but it's normally a rider issue not a board issue. You have plenty of ballast, so just try a few things before you buy anything more.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
