Results 1 to 10 of 17
Thread: Trailer Brakes
    Dec 2006
    Tuscaloosa, Alabama
    Default Trailer Brakes
    When I am returning home from the lake, I feel the brake or brakes drag for a short time and then quit. By the time I get home is rolls fine. I suppose I have to buy 2 calipers ($80.00 each) and an actuator ($160.00) to cure the problem because I don't know which one is causing the problem. Jerry, at Boatmate, says its a crap shoot and I can kind of agree. Any thoughts???? Jacked both sides up and is fine right now.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    You can try compressing the caliper pistons, then also bleeding the brakes, if it has guide pins clean and lube them.
    If that doesnt work then replace em.
    Dec 2006
    Tuscaloosa, Alabama
    I bled the brakes and now I notice that the travel on the actuator is less going back than it was before. I think this is a good thing. The trailer seems to stop better too. Will try this weekend to really see. My son is going through the Coast Guard Auxillary course tonight so he can get his boating license. Hope to have another driver
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Do visitors in AL have to have a "boating license", whatever that is?
    Dec 2006
    Tuscaloosa, Alabama
    Visitors are not required to have a license. You are good to go. I do see that more states are requiring licenses these days.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Oct 2005
    Durham, NC
    Yes, less travel on the actuator is better. It should be hard to compress.
    Brian Roberts
    2001 Outback DD
    Dec 2006
    Tuscaloosa, Alabama
    Took the boat out yesterday. Didn't have any problems with the brakes so hopefully they are okay.
    Put the GoPro on the wakeboard yesterday but have to upload it on youtube yet
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Quote Originally Posted by jmb View Post
    I still haven't found that pedal.
    Dec 2006
    Tuscaloosa, Alabama
    Pedal is small and hard to see but it is there
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Must be my eyes then.
