Results 1 to 8 of 8
    Apr 2009
    Raleigh, NC
    Default LSV locker support screw anchors
    I'm getting the upholstery on my LSV locker tops and engine cover replaced by a neighbor. I took some of the upholstery off of one of the lockers. I had a problem removing some of the screws that hold the strut support bracket to the aluminum board. The threaded tube thing that the screws anchor into had rusted a bit. I need to replace the threaded tube thing, but I don't know what it is called. From the side, it is T shaped. From the top it is circular with a hole in the middle. Also, it has 3 teeth on the edges of the circle that sink down into the aluminum board when it is tightened. Can someone tell me what to look for?
    05 Mobius LSV - gravity 3 ballast and wake plate
    single axle trailer
    DIY hot water shower installed
    DIY tube inflator installed
    Why not take a minute and shoot a pic of the part and post it up here?
    Apr 2009
    Raleigh, NC
    Unfortunately, I already threw them away.
    single axle trailer
    Des Moines, IA
    I think you are describing tee nuts: http://www.lowes.com/Fasteners/Nuts/..._/N-1z0yk2d/pl#!
    Apr 2009
    Raleigh, NC
    Those are the ones! Thanks!
    single axle trailer
    Des Moines, IA
    LOL Drew!!
