Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: New boat
  1. #21
    Aug 2008
    Cottage Grove, MN
    Default New boat
    Couple more with tower up.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
  2. #22
    Aug 2008
    Cottage Grove, MN
    I see reversibles and aerators - whatcha got in mind there? Or should I read through the whole thread more carefully...
    I got the pro ballast option which is 2-550lb bags in front, 2-250lb tanks in rear, and 2-350lb bags in rear (total 2,300lbs)
    Here are the highlights of changes I'll make:
    1. Add custom L-shaped enzo sacs (replace stock piggyback rear bag).
    2. Add additional fill pump to each rear side (so two pumps filling each bag).
    3. Add xLink pump (reversible) to shorten the time to change sides. Of the 5 in the family, I'm the only regular-side rider...
    4. Add dedicated drain pumps to the enzo sacs (current setup is that the bag drains down into the hard tank).
    5. Re-route drain and vent lines to the opposite side of the boat to prevent passive draining.
    6. Add check valves to rear fill lines to prevent passive draining.
    7. Front setup is going to be left alone, except that I'll T the drains and vents so that I can use the newly vacant thru-hull for the drains from step 4, and not have to drill any more holes in the boat.
    2008 LSV - Gone
    2013 other brand
  3. #23
    Tooele UT....
    Quote Originally Posted by mnpracing View Post
    comeon.. that's half the fun of buying a new boat
  4. #24
    Aug 2008
    Cottage Grove, MN
    haha, I did it on my LSV and didn't have any issues, but if I can get away with not doing it, I'll take that route and thanks again for the continued help with the wiring and all of my other questions regarding these mods
    2008 LSV - Gone
    2013 other brand
  5. #25
    Aug 2008
    Cottage Grove, MN
    Default New boat
    Picked it up last night. That's the Evolution cover on it, fits like a glove (a tight glove&#128512.
    2008 LSV - Gone
    2013 other brand
  6. #26
    Default New boat
    Nice!
    Except for those heavy coats. C'mon summer.
  7. #27
    Sweet grab the wet suits and get that thing in da water man
  8. #28
    Aug 2008
    Cottage Grove, MN
    Default New boat
    I got nervous when I looked out the window because the boat looked taller than our expedition, which fits in the garage with 3" to spare so I got Peggy to help me take the tower down (which is spring assisted so I just needed a spotter). But I took a 4 ft level and laid it across the windshield and the then high point of the tower and they both measured 6' 10". Whew! I upgraded the axles so they weren't sure how much this would add to the overall height.
    2008 LSV - Gone
    2013 other brand
  9. #29
    Aug 2008
    Cottage Grove, MN
    Default New boat
    We have other plans today so it will have to wait til next weekend.
    2008 LSV - Gone
    2013 other brand
  10. #30
    Aug 2008
    Cottage Grove, MN
    Default New boat
    It fits! 2" to spare. We left swim platform and VX on it.
    2008 LSV - Gone
    2013 other brand
