Results 21 to 30 of 36
Thread: In Bow System
  1. #21
    Belton, Texas
    Default In Bow System
    are you doing a full ballast line job or you gonna use a pump TeamLockhart
    sent from my home phone
    2009 Moomba Mobius LSV
  2. #22
    Nov 2003
    Land O Lakes, Florida
    Why do you need a check valve on the tank?
    Sent from my iPhone
    --you dont need one if your not running a ibs
    Quote Originally Posted by lewisb13 View Post
    He's talking about the check valve on the vent line. Spencer at wake makers really talked me out of one so we will see how it goes. The thought is that eventually you will just sick air and the ibs won't empty
    the vent line does not need a check valve, but, if you install a a ibs off the hard tank vent you run a tee fitting prior to the ibs with a spring loaded check valve on the end of hose, this way the ibs sucks down like a raisin and the hard tank is allowed to vent and drain fully. fully automatic for both and works wonderfully
    Quote Originally Posted by tnbrooks01 View Post
    Would you have to empty both legs separately with no check valve installed?
    no, both legs on mine empty 100%, hardly a drop of water in the ibs.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  3. #23
    Ahhhh I see! That makes sense
    Sent from my iPhone
  4. #24
    just to clarify, daze does have a check valve in his. it's cheap, so I'd put one in as I don't know if you could get the IBS to drain completely without it and only having one fill/drain port.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  5. #25
    Sugar Land, TX
    Why did Spencer talk you out of the check valve? Hard tank related?
    2011 Mobius LSV
    Ron
  6. #26
    Quote Originally Posted by rca View Post
    I dont think you need the check valve if you are running just the hard tank, it would only be beneficial if you t off of it like drew and daze did
  7. #27
    Correct. The check valve is only needed if you have the IBS and the cheaper, spring loaded ones from the big box hardware stores seem to work best.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  8. #28
    Apr 2011
    NY
    Yes, 2nd one:
    http://www.wakemakers.com/fly-high-i...d-bow-sac.html
    I posted up a how-to for the Mojo. Only thing I'd change is using a spring-activated check valve from Home Depot or Lowes vs the one from wakemakers. The wakemakers one is too good and creates a vacum in the center hard tank so that it won't empty.
    Do you mean like this?
    http://www.lowes.com/pd_104423-33599...acetInfo=Check valve
    '06 Outback - Gone but not forgotten
    '13 Mojo
  9. #29
    Jul 2009
    Marquette, Michigan
    This is how I am planning on adding an IBS to my Mojo. With this setup, I wouldn't need a check valve at all, correct? Is there anything stupid that I am overlooking?
    2013 Moomba Mojo 2.5
  10. #30
    Jun 2010
    Lake Houston
    Default Re: In Bow System
    How you gonna get the water out of the LEFT side of the ibs? Once the right side is empty youre gonna suck air through the vent line.
    2013 LSV
    2005 LSV - SOLD
