Results 11 to 20 of 36
Thread: In Bow System
  1. #11
    hey wolfey could I get the IBS bag and just use my tsunami pump to fill and drain instead of running a bunch of new lines and what not?
    sent from my home phone
    I'm not Wolfey lol
    Yes you can do that but its not an easy bag to install and remove all the time. It has to be folded and stuffed into the bow.
    but yes you can use a hand pump for filling and draining.
  2. #12
    Jun 2010
    Lake Houston
    Default Re: In Bow System
    He's talking about the check valve on the vent line. Spencer at wake makers really talked me out of one so we will see how it goes. The thought is that eventually you will just sick air and the ibs won't empty
    2013 LSV
    2005 LSV - SOLD
  3. #13
    Belton, Texas
    Default In Bow System
    no sir your not but in post #8 wolfey posted a pic of the bag. once I lay it in thou I wouldn't have to take in and out would I? couldn't ya just hook the pump up and fill then at end if day hook the pump back up to drain? then just leave in place once it's emptied?
    2009 Moomba Mobius LSV
  4. #14
    Feb 2010
    Canton, Ga / Lake Lanier
    Yep! Getcha one! Everyone's doin it
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  5. #15
    Absolutely, just make sure at the end of your season, or in your case, maybe every couple months you pull it out and make sure nothing is growing under it LOL.
  6. #16
    Feb 2011
    Skiatook Lake Oklahoma
    Would you have to empty both legs separately with no check valve installed?
    Todd
    2017 SUPRA SA450
  7. #17
    Quote Originally Posted by tnbrooks01 View Post
    If you use a hand style pump then you should be able to suck it all down as long as you can keep the pump primed.
    You wont get all the water out with a hand held pump but you will get it pretty close.
    When you integrate it to the onboard boat pumps you will want a check valve on the vent line to keep from sucking in air
  8. #18
    Nov 2009
    Nebraska
    One thing i did cause I am worried about not getting one side drained, is getting a new valve for my bag so i can get the other side.
    2016 Mojo
    2010 Moomba LSV-Sold
  9. #19
    I know there's a mom joke in there somewhere. Just can't get my hands around it.
    Sep 2012
    Clearlake Tx
    Chris just ordered 650 IBS and comes in on the 24th will let you know how install works out!
    2012 MOOMBA MOJO 345hp Surf Motor! Gravity III/ Engine water strainer, Heater, Acme 1235 prop upgrade, 2 Wetsounds Rev 10, Wetsounds Syn 4 amp, 12in Kicker substation with amp, Blue LED lights under ski platform, cup holders, speakers and Rev 10 rings! 1100 rear ballast bags, 650 IBS integrated into factory pumps.
    TEAM LOCKHART
    2005 Moomba LSV (traded on MOJO)
