Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
    Nov 2009
    Default Another Ballast Project
    Ok guys I have been running tsumani 1200gpm pumps that I have had a ton of priming issues ect. I want to make the jump to reversibles. Currently I have a single 1-1/4 thru hull and I am thinking that I can run two pumps off of that and install another 3/4 for the third. Am I going to have enough flow through the 1-1/4 to support two pumps?
    -Mark
    "Hey you only live once"
    Aug 2010
    NW Houston
    Somewhere during my rebuild, I found information to support running two impeller pumps on a single 1-1/4 intake - so I did. Seems to work fine with all 1" fill and 3/4" vent hoses.
    I think you're better off with a thru hull per pump with reversibles.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Mar 2009
    West Linn Oregon
    Quote Originally Posted by sybrmike View Post
    Multiple impeller pumps on a single intake does work, but over time you will see more wear on the impellers and pumps. With this said if it were an optimal solution, MasterCraft wouldn't have scrapped the system configuration after 2006.
    We do prefer that customers do it right the first time which will minimize any chance of a system problem long term.
    Jul 2012
    Cumming Ga
    If you look for my posts I set this up on a 1 inch thru hull and posted all the results look for the post it goes over the fill time differences. Bottom line it does take longer with 2 pumps on a single thru hull fitting but its not a ton of time. I am doing the same upgrade and decided to go with one port per pump. Spencer sold me everything through wakemakers.
    De Pere WI
    come on over. I love to drill holes in boats
    as they say... silicone shmilicone... fox river isn't that deep so it won't sink far if it does.
    I'd be more interested in the root cause of the priming issue?
    ^^ What he said. Priming on fill or drain pumps?
    Nov 2009
    Both. SandM and Berg both of you guys have considerably more room under floor to mount pumps. That is my biggest issue is that I have a really difficult time getting all three of the tsunami's under water level. I've fought it for two years now and I am ready to scrap it. Worse case I have some extra pumps for a bow sack, surf sack, ect.
    -Mark
    I want to do this too but I want detailed pictures of a boat that came with this set up factory. Pics of the thru hulls from inside the boat and outside, where the pumps are mounted, and how the hoses are routed
    Nov 2009
    Ok guys as soon as I get the WM code I am placing my order. I am going to run the two rear pumps on the 1.25" and the locker / ibs on a second .75".
    -Mark
