Results 1 to 9 of 9
    Aug 2012
    I live in Bostic, NC. I normally boat on lake James in Marion, NC
    Default Black mold spot removal
    So trying to get ready to go out for the first time this year. The black seems to have broken out it a black mold spot rash.
    Anyone have tips to remove these spots?
    Any ways to help prevent further out brakes?
    2011 Xlv with 325hp and stock Gravity lll
    Try other mild cleaners first. But, if you have to go harsh, use "Totally Awesome" from the Dollar Tree and a magic eraser. Be careful as the magic eraser is abrasive. Be sure to follow up with some 303 protectant.
    Aug 2012
    thanks ill try that. which 303 are u talkin about
    Nov 2003
    Land O Lakes, Florida
    mild cleaner and then park it in the sun for a few days
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Quote Originally Posted by jfox8807 View Post
    I get this at Boat US but I think you can order it from Wally's with free shipping to store if they don't have it:
    http://www.303products.com/303r-aero...tant-32oz.html
    Aug 2012
    Thank ill clean it agin park it in the sun then hit it with 303 protectant
    Jan 2013
    North Dakota
    I wonder how a steamer would work for something like this? I would think for sure it would kill off the mold spores, but you might still be left with the black mark that requires a cleaner anyways. I think it would be safe for carpet, but the heat may crack vinyl depending on where you have it.
    If you got one, give it a try. Be sure to dry in the sun afterwards since you are still adding moisture that surrounding carpet would pick up and any remaining spores would thrive on.
    2013 Mobius LSV
    2004 Centurion T5
    Pensacola, FL
    I have had great success with Starbrite Mildew Stain Remover. Follow the directions, it seems to work fine that way. Follow up with a vinyl dressing like 303.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    This may be a little extreme, but I had some bad spots on my yellow sections a few years ago. They looked purple and no amount of scrubbing or chemicals on the surface seemed to get them out. I got some very tiny needle syringes from the medical clinic I used to visit, did a 50/50 mix of water and bleach, and then injected it into the spots on the cushion. I held the needle at an angle almost parallel to the surface, if that makes sense, to avoid having a pin hole show. Did 3 or 4 spots and it actually worked pretty good and didn't get brittle. I figured I'd rather have a slightly lighter spot (bleached) than a dark spot showing.
