Results 11 to 20 of 24
    Feb 2012
    South Jordan, Utah
    Default Blue Sea add a battery help.
    Al,
    I got it figured out. I had forgotten to put the jumper from battery 1 to battery 2. Once I added that everything worked great. Thanks for checking back.
    Kurt
    2016 Mojo
    2006 Mobius LSV -Sold
    Good to hear. I kinda felt responsible since you were following my diagram
    Mar 2012
    South Carolina
    Which switch do you have, the traditional dual battery switch or the dual-circuit plus switch? With there be an ACR? Is an on-board charger part of the plan as well?
    The model # is 9100e? Ill have to take a picture tomorrow. No clue what am ACR is, and no there will not be an inboard charger at this time.
    Thanks for replying to my pm Al.
    I have to figure out a parts list other than the switch and some wire.
    I may just end up paying to have this done when I get down to SC, too much going on with the move.
    Where in SC are you moving to?
    The 9001E is a traditional OFF/1/BOTH/2 switch. an ACR is an Auto Combining Relay as illustrated in the diagrams above.
    Mar 2012
    South Carolina
    Most likely settling in Fort Mill by Lake Wylie. We're renting in Charlotte for 3 mos while we look for a house.
    Wylie is my home lake. Im just over the SC state line in NC and 15 minutes from the north end of the lake and 30 from the south end. Welcome to the area. 9 months of boating for the average and year round for the hard core.
    Good call and good luck with the move!
    rockwood tn
    I have the 13 mojo2.5 and was wondering if I can run the SI wire to the starter or does it have to be wired to the key switch if anyone can help me out that would be great thanks!!
    Riddle,
    The SI terminal on the Blue Sea 7610 ACR needs to see battery voltage ONLY when the start is engaged. Exactly where you draw this from is not as important. But in all honestly, its a circuit thats rarely needed.
