Results 1 to 10 of 16
Thread: Bimini install
    Nashville, TN
    Default Bimini install
    Here in the next couple weeks I will be adding a binimi to the boat(no tower), I have read all I can find on here and the rest of the internet about how to do it. I have a couple more questions if someone who has done this before can add some input. Ive read to tape it off with blue painters tape, drill holes in reverse, do a smaller pilot hole first. Sound about right so far?
    Now after the holes are drilled do I need to add silicon or a pad of some sort so water doesnt get into the holes? Also is there a particular type of bit that I should use or will just a new sharp bit due?
    If I am missing anything or any advice I will gladly take it as I am not excited about drilling into the boat, excited about the addition just not the holes..haha
    Thanks for the input.
    1998 Outback
    Jul 2011
    Murrieta, CA
    I would recommend sanding around the edges of the holes at a 45 degree angle to reduce the chance of spider cracks.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Curious what kind of tower? That may help to direct any more specific advice regarding padding/feet, support bracing, etc.
    The first hole is a nail biter. They're much easier after you have that one under your belt.
    Quote Originally Posted by BGeorge01 View Post
    Uh, I believe he said there was no tower.
    Doh! I need to quit drinkin in the morning...
    Well, don't over-react.
    Nashville, TN
    I will add this to the list, thanks
    would'nt do that, makes the day better!
    1998 Outback
    I know I know, everyone hates a quitter
    Mar 2013
    Murrieta CA
    I was gonna try and build a T top canopy for my tower next weekend and save about 600$.
    Has anyone ever had any success in doing this? Im going to try and make it strong enough to hold boards and what ever else I wanna put up there.
    I googled diy canopy's but not much came up.....
    Somebody on here posted an awesome DIY of their Z5 replica
