Page 11 of 19 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 188
Thread: Just Closed
  1. #101
    Pensacola, FL
    I think it is an anagram
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
  2. #102
    Default Just Closed
    Or a palindrome.
    Racecar
  3. #103
    Jun 2009
    South West Colorado
    Default Just Closed
    whats is sonos?
    www.sonos.com/system
    Check it out!
    '08 Mobius LSV- SOLD!
    2017 Mojo Pro
  4. #104
    so this does not really require any installation huh? Its all wireless aside from a 110V outlet?
  5. #105
    Jun 2009
    South West Colorado
    Default Just Closed
    Yes and no, depending on which Sonos products you are looking at. I prefer to pull speaker wire and install flush mounted speakers in the wall/ ceiling and then use the Sonos connect amp to power them. That is the cleanest option, but if that's not possible, the play3/ play5/ playbar work great if you have an electrical outlet at the location you want sound. They also have a wireless sub, which does a great job.
    2017 Mojo Pro
  6. #106
    Jun 2009
    South West Colorado
    Default Just Closed
    Also, At least one of the units requires being connected to your network/ Internet. It then creates a mesh wireless network that allows the other Sonos units to connect to the system. If you can't have one if the units hardwired to the network, you will need a bridge hardwired to activate the wireless mesh.
    2017 Mojo Pro
  7. #107
    Default Just Closed
    So you have to have either a speaker by the router or a bridge?
    Sent from my iPhone
  8. #108
    Jun 2009
    South West Colorado
    Default Just Closed
    Sent from my iPhone
    Yes, you need to have at least one Sonos piece hardwired to the router. Then, each additional piece extends the wireless mesh network. All you need to be concerned with is that any one piece is not too far away from the nearest piece that it can't pick up the wireless. FYI, the wireless is the same technology that network WiFi is, so that might help you figure out your relative range.
    2017 Mojo Pro
  9. #109
    Default Just Closed
    Ok so I have been at work for three weeks but we went by and checked out the progress as soon as I got home. Looks like the drywall and brick guys have been getting after it!
    Sent from my iPhone
  10. #110
    Default Just Closed
    Some exterior
    Sent from my iPhone
