Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 188
Thread: Just Closed
    Belton, Texas
    Default Just Closed
    I'm in New Orleans right now for a 2 day meeting today and tomorrow, then I head offshore Friday till Tuesday. Then Friday i fly to Russia for three weeks for a training school. Then as soon as I get home I go back offshore for a week and half. Then home for one week in may, then back offshore for three weeks. So by the time I get some
    Time off in June it will be like half way done or more lol.
    Sent from my iPhone
    hope your getting a nice raise, your work is taking up a lot of your lake time. hopefully your being compensated for such a travesty.
    sent from my home phone
    2009 Moomba Mobius LSV
    Hot chick delivering pizza and beer? They might just build that big garage anyway to stretch the project out!
    genius move!
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Default Re: Just Closed
    I dropped off a bag of diabetes and gatorade to our contractors last week.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  4. #24
    Default Just Closed
    Ok so our back yard does not come with grass, apparently that is our responsibility. I came up with about 2500 sq feet for the backyard, maybe a little more depending on the side yard and where the fence ends. A local nursery advertised a pallet of st Augustine for $130 and that's 450 sqft of coverage, so I'll need like 7. Anyone have any idea how much a pallet on this stuff weighs??
    Sent from my iPhone
  5. #25
    Portland Oregon
    Default Just Closed
    Just under 2,000 pounds.
    -Jake
  6. #26
    your truck can handle pallet, but that would be it. If you need that many pallets, you can try and negotiate free delivery from the nursery. Not a bad thing as you can direct them to spread the pallets around the backyard. Get plenty of help so you can get it off the pallets and on the ground ASAP.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  7. #27
    Default Just Closed
    I don't think they will be able to get a full pallet through the fence and I don't want them running over sprinkler heads with a fork lift...
    Sent from my iPhone
  8. #28
    When we did the back yard last year, they laid down 4/8 sheets to not run over the sprinkler system.
    Couple things to look at.
    How tall are the sprinkler heads, they need to come out of the ground about 4-6 inches to clear the sod and grass.
    Thats another thing you cant just put sod down on dirt or you risk killing it all. You will need to put down a mixture of dirt. I cant recall the mixture name but it has several things mixed and this allows the grass to bond and grow. Also you will need to use a TON TON of water every day all summer or the grass will die in the Texas heat.
    Our water bill was 100 a month higher then normal the first 3 months we had grass. We watered it at 4 am for 15 minutes, then again at 10pm for 15 minutes. The goal is it has to stay damp at the roots all the time.
    Depending on when your house is done it might be best to wait till Feb 14 to plant the back yard. We had our house done in June, but did the back yard in March for that same reason.
    Also with Sod if you cant get them to deliver, then you should rent a flat bed style trailer, it can handle more pallets. Plus its lower to the ground for unloading, and its a lot easier on your truck to Pull 2K lbs then carry it in the bed.
  9. #29
    Sent from my iPhone
    Take the fence down so they can. You will kill yourself carrying that much sod by hand from the curb to the back yard. Plus the more you handle it, the harder it is to work with as it starts to pull apart, etc. Or, you can run down to the QT with a couple hundred in your pocket and bring back some day laborers.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  10. #30
    Carrying sod gets real old real fast.
