Results 11 to 20 of 30
  1. #11
    Belton, Texas
    Default 2009 21v Supra Launch?
    let us know when you sign the deal and put her in for a solash
    sent from my home phone
    2009 Moomba Mobius LSV
  2. #12
    Lake Amistad, TX
    He said it doesn't have the Vision System, it's the Perfect Pass, and that something must be clogged in the front ballast because only the rear bags fill up when he turns his ballast system on!
    I'm hoping you ballast experts could reassure me this is an easy fix...?...
    2008 LSV Blue on White
  3. #13
    Quote Originally Posted by tgoody14 View Post
    Pretty simple, hit the center fill .. Pump on no water then a clog. No Pump? Look under the dash for the fuses or the circuit breaker.
    Also if you have a Pump Runs, no water, might be a bad impeller in the pump.
    Those should be standard jabsco style reversible.
    At the very worst, a bad pump your only 150ish and its an easy replacement.
  4. #14
    Lake Amistad, TX
    Niiiiiiiice! I knew you guys were good for something 😜
    Thanks Mike!
    You guys may end up talking me into this! Did he give you guys commission.... :/
  5. #15
    Supra all the way, nice looking boat. All good advice on here.
    May 2012
    Memphis, TN
    This is what the Vision System would look like for your refefrence. hope this helps
    2011 Supra 21V
    2012 Tundra SR5 Crewmax
    Wetsounds Icon8's
  7. #17
    Jul 2009
    Fort Worth, TX
    The lsv has a better surf wake and the 21v has a better wakeboard wake. It's just hard to get the 21v to lean over to one side, it definetely takes more weight to get a nice wave out of the 21v than the LSV. With the LSV it was super simple, 750 in the corner full and the ski locker 400 full and it was always a great wave. With the same set up on the 21v it is barely leaning to the weighted side, it's surfable but another 3 people or 400 pounds on the surf side makes it real nice. Being that it's hard to get the 21v to lean to once side it has a very stable wakeboard wake, and in my experience with the 21v compared to the LSV, the 21V got bigger with less weight and cleaned up at a lower speed than the LSV. The 21v also has a firmer wake with a little more transition. Anything else you're wondering about comparison wise lemme know. The frist pic is the only pic I could find of the 21v surf wake, second pic is the LSV, as mike and others have said it's noticibly shorter than the LSV wave.
    -2012 Supra Launch 21V
    -2008 Mobius LSV
  8. #18
    Lake Amistad, TX
    Thanks Votto
    Blackout - thanks for the pic! I recognize the pyramid! I grew up 45 minutes from Memphis in NE Arkansas!
    B - great info, good to know on the differences of weighting the boats down!
    If you guys run across any newer model LSVs on your local craigslist let me know!
    I still travel back home to Arkansas quite often so anything in TX, AR, MO, MS, or LA is within driving distance for me!
    Thanks Again guys!
  9. #19
    Arkansas
    Are you ruling out your buddy's Supra? My condolences on the NE Arkansas deal
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  10. #20
    Lake Amistad, TX
    Get outta here KG! That is God's Country!!! Haha I have to say tho I don't miss those AR winters and crazy springs when you get the random snow in March!
    I'm just letting him sweat it out until I get home on the 5th! He knows im interested, but i know he Is just itching to get a New boat. Maybe he'll come down some more or throw in some extras and in the meantime I'll keep looking for LSVs. If nothing, then I'll prolly tow the 21v back to TX
