Results 1 to 6 of 6
Thread: Cooler removal
    Aug 2011
    Default Cooler removal
    Had some warmer weather today so I removed the cooler from my lsv. Getting ready for my new ballast setup..
    Die grinder & sawzall
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Aug 2012
    I live in Bostic, NC. I normally boat on lake James in Marion, NC
    very nice. i was thinking about taking my cooler out in my xlv. was gonna put 3 more batts back there for more engine off play time
    2011 Xlv with 325hp and stock Gravity lll
    Nice ill be doing the same in the next few weeks 370 sac there I guess are you integrating it into your existing system or using a tsunami pump
    Aug 2011
    Default Re: Cooler removal
    All new system with 4 reversible pumps..
    Feb 2010
    Canton, Ga / Lake Lanier
    Mine's gone...cut it out last summer...in the dark...best mod I've done....
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    I removed the one on the LSV as well last summer. Was no much nicer having the extra storage room.
    New owner was glad it was gone as well.
    I will however CAUTION you... If you run a ballast bag up there you need to figure out a way to mount a L brackit or something.
    I was running a 450 bag for a while, and with that plus people siting on that side of the boat, the fiberglass bowed out almost 1/2inch from it normal sitting place. I have to push it back in and get it lined back up to its original place. The cooler is providing some anti-flex to that section of the boat.
    Might be as easy as taking some aluminum L brace and epoxy them to the inside wall of that area, or mount it to the under side of the lip and to the floor.
