Results 11 to 20 of 20
    Sep 2005
    Claytor Lake, VA
    It has a smoke tint cover. Follow the black 1/4" tubing. Here is a pic of the tank/pump unit.
    http://www.bennetttrimtabs.com/image...g/V351HPU1.jpg
    2005 Mobius LSV
    Oct 2008
    Central, Arkansas
    Found a pic of my '02 LSV with the pump location.
    Mine is in the engine compartment near the pylon..
    2006 Moomba Mobius LSV
    Jun 2011
    Bryan, Texas
    Default Wake plate problems
    Finally got around to looking into my wake plate problem. Works been killing me!! It was low on fluid so I added some which helped. But it will not go lower than level with the boat. Took the lower screws off to make sure the plate was not jammed. Still won't go any lower. Does anyone Have a suggestion?? Thanks!
    2004 Mobius LSV
    Jun 2009
    South West Colorado
    That's about as low as mine will go on my 08. Mine goes only just past the plane of the hull. How much further are you thinking it should go?
    Sep 2005
    Claytor Lake, VA
    Work the plate up and down a bunch of times and check the fluid level and top it off if needed. My have air in the system that just needs to be worked out.
    2005 Mobius LSV
    Feb 2005
    Ottawa, Ontario, Canada
    Could someone please post the specific kind of fluid needed? I need to top mine up, but the owner's manual does not specify. I'll buy some today to top up at the lake tomorrow at the marina (which is where my boat is).
    Thanks in advance.
    Feb 2005
    Quote Originally Posted by Ian Brantford View Post
    Thanks in advance.
    I know that it's ATF. I want to know what kind specifically. For example, the transmission takes Dextron III.
    Default Re: Wake plate problems
    Same stuff...
    http://www.bennetttrimtabs.com/trimtabtips.php
    Feb 2005
    So, any ATF will do. Asked and answered. Thanks!
