Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Yearly service?
  1. #11
    Quote Originally Posted by wakeboy View Post
    Do I need to drain the prestone i put in the hose and engine last year when I did my winterization before running the boat this summer?
    No when you put the boat in the water and start it, it will flush out.
  2. #12
    thank you
  3. #13
    Default Yearly service?
    Regular automotive antifreeze such as Prestone contains toxins and you'll be putting those right into your lake. Maybe/probably not a big deal unless your in an Army Corps lake and an officer is within sight or if you give a crap about the environment.
    If you use RV antifreeze next fall/winter, it's environmentally safe and you can drop it right in, but it's probably better to crank it up for about 10 sec with a container under the exhaust ports and dispose of it properly. A lot of oil change places will take your used fluids.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  4. #14
    I have looked for this zirk fitting on my steering cable and have found nothing...
    Sent from my iPhone
  5. #15
    Portland Oregon
    Sent from my iPhone
    At some point the design was changed at it is no longer required to lube it. Funny thing is the older manuals (I only looked up to 04) say to lube it but never show what it is or how to do it. Then I looked in a 2012 manual and there's no mention of lube-ing it at all. So I can only assume its been changed.
    I never knew about it until my 91's steering was extremely stiff one year when I took it out for the first run of the season, that boat had the zerk right on top of the rudder in the hull.
    -Jake
  6. #16
    Las Vegas, NV & Denver, CO
    Quote Originally Posted by mobius maximus View Post
    Ive been searching through all the threads and cant seem to find any about typical yearly servicing. This is the first time I'm having to de-winterize my boat since I bought it. Just trying to find out what i should replace/service as far as typical yearly servicing goes. Fairly new to the boating/ moomba scene. Thanks.
    Wondering this myself, just had the "gold Service" done in late November- all fluids changed, oil changed, impeller changed out.. Last year I had the oil changed again and services done again before I took it out here in March... But thinking that may be quite a waste of money, is it really needed before I take it out?
    2014 Moomba Mojo- Exiled Out!!
    04 XLV- 2 REV 10's & REV410- All JL Audio amps
  7. #17
    If you haven't run the boat since November, then you don't need to have all the fluids changed again to start the season.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  8. #18
    Aug 2011
    Default Re: Yearly service?
    I have this..
    http://m.westmarine.com/webapp/wcs/s...&ci_sku=313820
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
