Results 1 to 10 of 15
Thread: Impeller Puller
    Jan 2013
    Northeast, PA
    Default Impeller Puller
    I am looking at buying an impeller puller to make my life a lot easier. I found two puller online, one by
    Sea-Dog Stainless Steel Impeller Puller for $44.99 and Jabsco Flexible Impeller Puller for $89.99. Can anyone tell me if the Sea-Dog SS Impeller puller is worth the money or just spend the extra money for the Jabsco puller?
    Jabsco
    http://www.overtons.com/modperl/prod...r&merchID=4005
    Sea-Dog
    Thanks,
    Mike
    2007 Moomba Outback V
    Yikes... Instead of $50-90 I'm thinking something like this along with a little WD-40 would do the trick.
    http://www.sears.com/great-neck-bent...4&blockType=G4
    Unless you plan to be pulling a lot of impellers.
    Nov 2003
    Land O Lakes, Florida
    Never used a puller myself, 2 screwdrivers and a pair of pliers and a little brute force and out it comes
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Oct 2008
    Central, Arkansas
    Spray the impeller shaft with WD40, pull the coil wire off, bump the motor over a few times, then I use 2 paint can openers to pull it out....
    Quote Originally Posted by mcdye View Post
    Bingo thats how i do it. Then wipe a little oil on the new ones fins and she slides right in
    Mine new one always seems to come with a little packet of silicone lube to lube it up for reinstall.
    I used the dual vice grip method, oil, bump, install two pairs of vice grips 180 degrees from each other and pull like hell...sometimes it may not be useable as a back up when it gets out but it gets it out...
    Jun 2010
    Lake Houston
    Default Re: Impeller Puller
    Two paint can openers works perfect
    2013 LSV
    2005 LSV - SOLD
    Quote Originally Posted by lewisb13 View Post
    never had luck with this method. just got extremely frustrated
    Jun 2010
    Lake Houston
    Lol I wasn't really directing my comment towards you David I actually have done it with pliers as well and that ultimately worked too
    2013 LSV
    2005 LSV - SOLD
    What ever brad. I know you were taking cheap shots at me....
    Just kidding
    Sent from my iPhone
