Results 11 to 20 of 32
    I am really curious now as how big this hill actually is!
    Portland Oregon
    Default Anyone using a trailer brake controller?
    Worst one I tow and we have no shortage of volcanos around here. People often come down smoking and dunk their red hot trailers straight into the water! Very hard on equipment!
    I've been running around Cove my entire life and only recently gained access to this area. It is a gated private community with miles of paved roads and this final stretch to the boat ramp is exactly what MM said, BRUTAL.
    The first time I ever came down there I was in second gear and overheated my truck and trailer brakes. Now at the viewpoint I pull it down into first gear and turn off the trailer brakes. Truck brakes now get warm but not hot. My truck has 4:10 gears too, second gear usually gets me down steep hills with very little braking.
    Now I'm thinking might as well do it right and wire it to a switch and the reverse lights. I wonder if I need a relay to stop my switch power source from sending signal to my reverse lights on the truck? Does that make any sense?
    -Jake
    Portland Oregon
    Forgot to add pic of said viewpoint.
    -Jake
    I don't think it would matter if your truck reverse lights were on while going down the hill...
    Traverse City, MI
    My Jeep has the reverse light wired, I was more thinking that I ha trailer brakes that weren't being used since I didn't have a controller; I didn't realize it was all automatic
    Feb 2010
    Raleigh, NC
    Ian, try this...unplug the lights (so the reverse sensor is not active) and try to back the trailer up a small hill. You will quickly realize your brakes are working!
    Jeff
    2012 Outback V
    Yes sirs - you are correct. I got off track a bit there and lost my train of thought... (gee, that never happens)
    You could take that 5th wire for the reverse light and hook it to a separate switch as opposed to your headlights... Then you could control the brakes on/off at will. Wouldn't be too tough.
    Here's a few more shots of the canyon going into LBC. This is the kind of place where you can be out on the water 3ft from shore and it's 100+ft deep. Cliff country.
    is that mt Raineer in the 2nd photo
    boy do I miss that part of the country
    I wanna say that's Mt Jefferson. Rainier is further north outside of Seattle.
    Portland Oregon
    Cliffs?
    So maybe I was over thinking it. Can't wait till Memorial Day to go back. Even though the water will be 60*!
    -Jake
