Results 1 to 10 of 13
Thread: Prop
    Feb 2011
    Skiatook Lake Oklahoma
    Default Prop
    I know this topic has been discussed time and time again and I've searched the forum and gone through just about all the threads regarding the topic already but I'm going to bring it up again.
    Ill be picking up the new boat ('13 LSV with surf motor) in about 10 days and will be making the prop change right off the bat but I haven't solidified my decision yet as to which prop. I plan to do the ballast upgrades at the same time as well, which will consist of 2-1100s, 2-370 tubes, center tank, and IBS. We don't ski, tube, or cruise the lake so I'm looking for the best prop for wake boarding and secondary surfing.
    I'm torn between the 1235 and 1433. My concern with 1235 is clearance? Is the clearance issue for this prop with the prop guard or the LSV hull itself? I know if its with the trailer I could shim the bunks but then I run into potential garage clearance probs. And if its with the hull I don't want any "prop burn" issues either.
    Will the 1433 be enough when loaded down? We usually ride with a small crew so that's why I want so much ballast capacity.
    I will be contacting the folks at Nettles next week but wanted to check here too for feedback.
    Todd
    2017 SUPRA SA450
    Default Prop
    I believe the 1235 clearance issues are with the trailer. Never heard of a prop burn issue
    Sent from my iPhone
    Portland Oregon
    Default Prop
    There is no noticeable performance difference between the two so if clearance us a concern get the 1433.
    -Jake
    Feb 2013
    Default Prop
    Diameter is not near as much a factor as proper pitch. It would be advisable to go out and run it testing all maker of boating conditions and speeds and rpm to make a more informed choice.
    Nov 2003
    Land O Lakes, Florida
    I have the upgraded Acme 1235. ordered it with boat. no clearance issue's that im aware off, Ive driven on and off the trailer and no contact. Pretty sure theres about a 1/2" or more of clearance with the prop guard
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Feb 2011
    Default Prop
    When you order that prop as an upgrade from factory do they shim the back of the bunks on the trailer?
    Todd
    2017 SUPRA SA450
    Nov 2003
    Quote Originally Posted by tnbrooks01 View Post
    not that i have noticed, when I get home tonight I'll double check, but I'm pretty sure its not shimmed
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Jun 2010
    Lake Houston
    Default Re: Prop
    I have the 1235 on my 13 lsv and there aren't any clearance issues. Ordered it like that from the factory though
    2013 LSV
    2005 LSV - SOLD
    Feb 2011
    Default Prop
    Going to give the 1433 a shot. Should be here first of next week and pick the boat up next Friday.
    Todd
    2017 SUPRA SA450
    Aug 2006
    I ran 1433 on my LSV and was pleased..
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
