Results 1 to 7 of 7
    Feb 2010
    Canton, Ga / Lake Lanier
    Default Roswell surf racks
    I'm going to add two Roswell swivel racks soon and I'm wondering if I should get two of the surf racks or one surf and one wakeboard rack. Does anyone have the surf rack? Will the surfboard slot hold a skim style board ok? I have two surf boards and both are skim style. I know they fit fine in the stock factory racks. I'm sure I will get a surf style board before too long so that is why I'm getting at least one surf rack.
    We are going to keep the factory racks on for if we have more than 4 boards on the boat. We usually go out with 3 wake boards, 2 surf boards, and this will be our first season with a skate (LF Faction) on board. Will the skate fit in the wakeboard rack or should it go in the surf slot. If it should go in the surf then I'll probably go with 2 surfs. Will the surf slot hold a wakeboard ok too?
    I'd like to swap out the factory racks with another set of these swivel racks but they are far too spendy for 2 sets. Or maybe we just carry too much gear. I suppose a Z5 or the Monster tower version would solve that...
    Wow! Sorry for the rambling...
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Aug 2011
    Charlotte, nc
    not to highjack but my question coincides with this. Has anyone added just the swivel piece to their existing factory roswell racks?
    2014 SC350
    2012 LSV - sold
    Feb 2010
    Quote Originally Posted by freshturk View Post
    The Moomba factory tines do not have the Roswell plate, that is what needs to mount to the swivel. So just the tines will not work.
    Tow Rig:
    Feb 2010
    Also, you will need to buy the universal clamp as well...separately...to mount the rack to the tower. Neither the swivel nor the rack comes with the clamp...
    Tow Rig:
    Feb 2012
    St. Albert, Alberta, Canada
    And it won't swivel properly, because of the angle of the rear tube. I'm looking at getting a square block welded on the tube, so it sits level with the boat, and will clear some XM9's. ImageUploadedByTapatalk1362265667.330573.jpgImageUploadedByTapatalk1362265697.879675.jpg
    And the surf tines fit a Ronix Koal no problem. I'll get pics of the throat measurement when I get home.
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
    That's OK. We can help you pick the flower colors for your wedding too. Oh wait. You are already married. Maybe we can help with the drapes. Sure. Just post up all your possible color choices and we'll get Dusty to make a recommendation. What are you asking???????????????????????????
    Feb 2010
    Basically will the Roswell Surf rack hold a wakeboard, skim style surf, or wake skate securely enough in the surfboard slot?
    Tow Rig:
