Results 1 to 10 of 20
    Dec 2012
    Trois-Rivieres, Quebec
    Default Where to install my amp
    Hi all,
    Now is time to install my amp on my 2006 Outback. Any suggestion ? Any picture to share ?
    Thanks........snow storm here in Quebec !!!
    Most people opt to put in the passenger side cubby. It's dry, out of the way, and close to the battery(ies).
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Aug 2012
    this is how i did mine. i have an xlv but maybe itll give you some ideas.
    Dec 2012
    Quote Originally Posted by jfox8807 View Post
    Nice....but on my outback, I don't have that wall you fixed the amp to......I only have à small panel attached to the boat hull....so i'm afraid to drill it at that location...
    Dec 2012
    thanks jfox....
    did you fixed the amp to the ''wall'' of the boat ? or did you install a new wall. If yes, how did you fixed the new wall?
    Not sure what Jfox did but I've seen several guys remove a small piece of carpet where the hull is, glue wooden/plastic blocks to the hull and then use those blocks as a place to mount an amp panel.
    Creating a panel for the amp, opposed to screwing it to the hull will save you time in the cubby and possibly save you from any issues. A local shop around here screwed an amp to that outside wall and sent a screw through the hull of an X2.
    I used a panel that goes across the back of the cubby, supported by blocks that were screwed to the floor or the bow seat back. The rack on the right side I did actually screw to the fiberglass but I think I'd go the block route if done again.
    2016 Moomba Mojo
    Hey, KG, you spelled "when" wrong above.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    LOL! Ain't that the truth. You guys have me thinking about relocating my amps and making a new board.
    Similar to the above suggestions, I cheated a little. One side is anchored into the venting channel using L shaped brackets attached to the amp board. On top I made a bracket that ties into one of the tower mounts or was it the cleat mounting bolt. Can't recall but it works, hides wiring and doesn't move.
    Did the same on the bottom and anchored them to the floor. Nothing is stuck to the hull side on mine.
    Those pics are older but hopefully you get the idea. When I redid it a year or two ago I used gray galvanized L brackets and tucked them in tighter so the carpet lays over it better and covers any trace.
    Dec 2012
    thanks all........removing some carpet on the vent channel and glue blocks to received the amp panel will be the best option...thanks again !
    And now, shoveling the snow again...viva Québec !!!
