Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Apr 2011
    Edmonton, AB Canada
    Default 2009 LSV Garage Dimensions
    Hello
    Building a house and looking for some advice on the garage size requirements to fit a 2009 LSV
    The manual shows:
    Overall width with trailer - 102" (8' 6")
    Length with trailer - 25' 3"
    Length with platform - 23' 6"
    Length without platform - 21' 6"
    My questions are:
    How high is the boat with the tower folded?
    If I pull the platform will the total length (including trailer) be 21'6" or stay at 25' 3"?
    Are the lengths in the manual with the tongue folded?
    My house plans call for a 25' length garage, with an 8' wide by 7' high garage door.
    I will have to get at least a 9' wide door, just confused on if I really need more length (25' 3") and can't seem to find a height with tower folded.
    My boat is in storage and not easy to access until the spring.
    Thanks in advance for any for any input
    Cheers
    Kirk
    Aug 2008
    Cottage Grove, MN
    This is based on an 08 on a tandem axle trailer: It will fit a 7' door with tower folded, but ONLY if the tongue is lowered while backing in. With the tongue at trailering height (level) it is just an inch or so too high (depending on how accurately the builders made the framing). Go at least 8' if you can since you have the opportunity now. I think single axle trailers sit higher, but I'm not sure. You'll need the wider door too. Even at 9' that's only 3 inches on either side of the boat, so you have to be pretty good at backing that thing in.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Quote Originally Posted by mnpracing View Post
    The width is without the guide poles, so you have to remove them as well, they stick outside of the fenders.
    Length with trailer - 25' 3" this should be 23.6
    Length with platform - 23' 6 this should be 25.3
    The boat on the trailer, with out the swim deck and a folding tongue will fit in a 23ft deep garage. There wont be but a couple inches forward and aft.
    As for Length i think you got 2 numbers mixed up.
    Nov 2009
    Nebraska
    How do you lower the tongue?
    2016 Mojo
    2010 Moomba LSV-Sold
    Apr 2011
    Edmonton, AB Canada
    Apr 2011
    Edmonton, AB Canada
    Mike I am not sure about your length numbers?
    The ones I posted are right out of the manual
    Nov 2009
    Nebraska
    Quote Originally Posted by KEH View Post
    Will the trailer be able to reach it if its that low? I have a 2010 and want it to fit in my garage but it is about an inch to high.
    2016 Mojo
    Apr 2011
    Edmonton, AB Canada
    Not positive if this is what he meant by lowering the tongue...it was the only option that came to mind.
    Perhaps mnpracing could clarify?
    Default Re: 2009 LSV Garage Dimensions
    Some use a drop hitch, others have to unhook the boat from the tow vehicle and lower the jack.
    I guess its how you look at it but this is the way i see it.
    The boat and trailer are longer then this with a Swim deck and shorter without..
    Boat on the trailer with out a Swim deck is apx 24.4 feet including the wake plate.
    Its apx 26.5 on the trailer with a swim deck.
    Length with platform - 23' 6" This is just the boat, no trailer
    Length without platform - 21' 6" This is just the boat with no trailer
