Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 134
Thread: Plasti Dip
  1. #51
    Belton, Texas
    Default Plasti Dip
    Quote Originally Posted by Boonejeepin View Post
    Picked up an can and dipped my company car emblems.
    Cool stuff!Attachment 16745
    looks great and to easy right?
    sent from my home phone
    2009 Moomba Mobius LSV
  2. #52
    Jul 2011
    Murrieta, CA
    Default Plasti Dip
    Very easy. I found that I don't need to tape close at all. It does help to have a little warmth to the air. It did not want to cure with the garage around 50 degrees. I warmed it with a hair dryer for a couple of minutes and then it was good to go.
    If I had the chrome Moomba letters I would be all over it.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  3. #53
    Belton, Texas
    Default Plasti Dip
    same here, the letters are gonna look to good blacked out
  4. #54
    Easier than washing anyway.
    So the consensus is this (the spray kind) won't hold up well to high traffic or highly handled / wear and tear items?
  6. #56
    Jul 2011
    Murrieta, CA
    Default Plasti Dip
    It is tuff but I think it would need to be pretty thick for a wear area.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
  7. #57
    Belton, Texas
    Default Plasti Dip
    I think if you put enough coats on it will be fine. my front emblem and light covers have been on highways speeds and high pressure car wash with numerous direct hits from power washer hose and no issues. did a skate board for kids and no issues so far either. if it does come off in a spot or two it's easy to fix, just touch up with your can of plasti
  8. #58
    Man, I want to do it, but I dropped some $80 on the chrome reg numbers and I'm worried the DNR won't go for those being blacked out on the black part of the hull. Do you guys that have used it think it will work on the "MOOMBA" decals on the transom and the "MOJO" on the rear sides, too? It's more of a domed sticker material than the side chrome ones.
  9. #59
    Belton, Texas
    Default Plasti Dip
    I think it would work fine drew.
    with your reg numbers up front you can spray them black then use a plastic razor blade and trim about an inch around so that way you have part chrome part black to add a little "pop" to the reg numbers.( like boone's Chevy emblem) or you can black out and it water cops tell ya it's a no go just remove the plasti
  10. #60
    Arkansas
    Worked on my stapler ... I bet you will be fine.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
