Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
  1. #31
    This site has the better specs on the exile amps
    http://www.exilecaraudio.com/
    I like that Video Spotlight right thar in de middle
  2. #32
    no simple answer for David ?
    From Exile's website, I was able to gather his amp's total fusing.
    800.1 = 60A (2 x 30) I would use a 50 or 60 amp
    Harpoon = 80A (2 x 40) I would use a 80A
    SM600.1 = 50A (2 x 25) I would use a 40 or 50 amp
    For the main circuit protection, I would use a 120A or 150A breaker or fuse. As noted, the amp's estimated current draw will depend on some variable factors such as battery level, volume and music type, but it also depends on how many chnls are running at 4 ohm and how many or running at 2 ohm. The load on the chnl dictates the amps output, thus the current draw.
  3. #33
    MLA thanks for the input i was going to use 125 across the board
    here are two more amps
    Xi2500.1
    Xi1500.1
    into 1 ohm
    2500W x 1
    1500W x 1
    Reccomended Fuse Size
    200A
    100A
    Power / Ground Wire Size
    1/0 Gauge
    4 Gauge
    I thought that Rockstar looked familiar...
    Jul 2009
    Fort Worth, TX
    Would a single 1/0 gauge input be enough for four 4 gauge outputs? Thinking about adding a fourth amp in the future.
    -2012 Supra Launch 21V
    -2008 Mobius LSV
  6. #36
    Quote Originally Posted by bzubke1 View Post
    Yes it can, but it would depend on the collective potential load of your 4 amps and the total length of the 1/0 cable.
  7. #37
    If your running the harpoon at 2ohm would it increase the fuse rating from 80 to 160?
    No. The Harpoon has 2 40A fuses plugged into the end panel by the power terminals. This is based on its max potential current draw @ 2 ohm x 2.
  9. #39
    cool so i can use a 250 resetable breaker from the battery to the block, then match each amp rating from there on out assuming the cables are properly rated..
    great info thanks.
    With 12" of 1/0, you're with a 250A breaker. I think you could go with a 200A if you are going to run the 1500.1 @ 2 ohm as opposed to 1 ohm.
