Results 11 to 20 of 41
    Thanks David,
    Was not sure how it looked wired up.
    Default tsunami power and grnd distro block with meter
    No problem
    Aug 2012
    same block i use in my boat i like it works good the cover is a little kesie i guess. when i first skrewed it down i got it to tight and the cover wouldnt snap on loosend up the skrews up a bit and the cover snaped on and been good ever since the volt meter does go out un less u got the system jacked up loud and it causes ur voltage to jump around a bit.
    i also noticed u said u got anl fuses. if u got regular anl fuses they want work u gotta make sure u got mini anl fuses hate for u to not be able to use ur new toy cause u and got 5 dollars worth of fuses
    Thanks, i did get the mini anl fuses, with blue led.
    good feed back on the cover, i hope the volt meter works better than what you guys have reported, but no big deal if not,
    Apr 2011
    NY
    JM-Exactly what I used on my amp panel. Panel is in basement not on boat if you want I can remove and you can take a look in person.
    '13 Mojo
    Two more questions?
    since the boat is in winter lock down....
    on the 2011,2012,2013 models have a 125 fuse or breaker running from the stereo battery to the bulky stereo bus bar configuartion or do i need to get one.
    Two, will i need three batteries with three amps ( Exile, harpoon,800.4 and 1500.1) we dont spend all day party coving it, so stereo is usually running when the boat is.
    J,
    In actuality, you only need a single cranking battery to run the boat and entire stereo. Now, how many house batteries will be needed to power the system with the engine off, will be determined by their estimated current draw at "Z" volume level x "Y" minutes you want to play the system with the engine off. This will give you an estimated battery Ah number. From there, you can figure out what group size and how many will be needed.
    Im not sure I understand what you are asking in your first question. If there is an OEM installed B+ and GND BUSS Bar on the amp wall, they may be usable for your install as all 3 of those amp have internal fusing. But, you will need to supply those BUSS bars with proper gauge cable and circuit protection.
    J,
    GTK on the 3rd batttery,
    on the stereo bus bar + and -. It takes up alot of real estate on my amp board and thus the combo distro block, wanted to know if they fused the power supply from the battery to the + side bus bar for the stereo.
    I will try to post up a pic.
    upper left hand corner
    That is a rather large BUSS. I would hope it has some sort of circuit protection, but im not sure of that cabling would be sufficient to carry the possible load of those 3 amps combined. I have a feeling that you will need to upgrade the trunk like, regardless of swapping out that BUSS for a B+/- combo distribution block.
    It also looks like that is 10ga running to that 700.5 amp. 4ga minimum, IMO. Not uncommon to see them bench test at over 900W rms.
