Results 1 to 6 of 6
    Default Wiring The tower for speakers
    How hard of a job is it? I just bought tower speakers for my 2002 Outback and need any help or advice in wiring the speakers.
    Mar 2003
    Mississippi
    Default Replying to Topic 'Wiring The tower for speakers'
    Very easy drill your holes where you want the wires to come out for the speakers. There should already be a hole at the bottom of the tower near the hull. Feed some dental floss in this hole. Put a shop vac over the holes you drilled and suck the dental floss through. Tie your wires to the dental floss and pull them through. We did two towers this summer it took about 15 minutes.
    Thebeez
    Mar 2003
    Springfield Missouri
    You probably didn't think you would be "fishing" in your boat.
    1998 Mobius
    310 HP PCM
    SOLD
    Do I need any special wiring?
    Feb 2004
    The biggest issue is finding a thru the hull connector. You have to buy a whole wireing kit from moomba to get the connector then you need special tools to make the connection. This is only if you need to make the tower removable.
    I do not plan on removing the tower, I may need to tilt it forward but that is it. I figured I just put a grommet in the top of the hulland run a wire thru it
  1. Help needed wiring tower speakers
    By phenom_1819 in forum Boat Owners
    Last Post: 05-07-2008, 01:50 AM
  2. Wiring Tower Speakers, Please Help
    By Mallardhunter83 in forum General Chat
    Last Post: 02-04-2008, 09:42 PM
  3. TOWER LIGHT WIRING
    By drewdwn in forum General Chat
    Last Post: 12-31-2007, 06:25 PM
  4. Wiring new tower lights
    By moomba_armada in forum Sales & Information
    Last Post: 12-26-2007, 05:39 PM
  5. TOWER SPEAKER WIRING HARNESS
    By Gharvin in forum General Chat
    Last Post: 07-05-2005, 02:38 AM
