Results 1 to 10 of 10
    Oct 2002
    Salt Lake City, Ut
    Default Swim platform brackets
    On my 2001 mobius v. the brackets that hold the swim platform have 3 bolts on the top that have nuts on the inside of the boat, but the bottom 2 bolts just screw into the boat into some wood or somthing, I cant even find a way to get to the back side of the bottom bolts on the brackets, the holes are compleetly stirpped on both sides, and if you pull up on my platform, it pulls the whole bracket away from the boat. It's cracking the fiberglass around the brackets, and causing some good leaking into the boat, Anyone got any ideas on how I can fix this? Would somthing like this be under warranty.
    Aug 2002
    Bismarck, NorthDakota
    Default Hmmm
    I have often wondered if anyone else has had this problem. I too have a 2001 Mobius and after the first summer I noticed some spider cracking around the swim platform. I thought it was just cosmetic, however I took it to a local glass shop and they thought otherwise. After contacting Skiers Choice and working out the warranty details we went ahead with the repair. They ended up cutting two, 1 foot by 1 foot sections out of the back around each platform foot. They put in two thick pieces of alumminum (SP) and reglassing. They did an excellent job, the boat looks great and the swim platform is stronger than it was from factory. I suggest you talk to your dealer about warranty.
    Bruce Fuerstenberg
    Feb 2003
    Spokane, WA
    Default swimplatform brackets
    vdawg,
    just a short note, we have a 2000 kamberra(same as the mobV) and we had a similiar problem. Skiers Choice worked with us and a local glass shopto fix it. It turned out to be a warranty thing and they were really greaat about it. The glass shop had to replace the filler between the fiberglass layup. The platform is now stronger than ever. Great boat and lots of fun with almost 200 hours on it. Hope this helps.
    tygger
    Feb 2003
    Spokane, WA
    vdawg,
    tygger
    Apr 2002
    Greenfield Indiana
    Platform Concerns,
    Have been reading this thread with interest. We have a 2000 Outback/LS and luckily have yet to see this problem, but does not mean it will not appear at some point.
    If this comes up later in the boats life is it covered by Skiers Choice "Limited Lifetime Warranty for the hull, deck, floors and stringers"? Or is it something I should have addressed now as preventative?
    Apr 2003
    Powhatan, VA
    Default platform
    Me too. Ours is a '99 outback. No stress cracks, no looseness so far. Could it be a non-issue for '99 and '00 ????
    Aug 2002
    Maryville, Tn.
    Default Rest Assured
    The Outback hulls have not had a single issue with that problem. I feel comfortable, stating that, there will be no direct connections between these concerns. Brian Raymond
    Jun 2003
    Chicago, IL
    Default Swimplatform concerns
    I have a 2001 Kamberra and have noticed spider cracking around the swim platform brackets this spring. Is this problem with the 2001 Kamberra.
    01KAMBERRA
    Sep 2002
    Paris Texas
    I have a 2001 mobius V and I am having this problem.
    Shawn
    Feb 2003
    Spokane, WA
    RD and PIKE1990
    I had a similiar problem with our 2000 Kamberrera, started with us noticing the spider cracks. Skiers Choice was great in working with us through our dealer and with a local glass shop to get it fixed. Hope that this helps. Really enjoy our Boat and saved enough on the boat to get a new tow vehicle too. Hopefully will have pix in the future to show everyone
  1. Swim Platform Help
    By JesseC in forum General Chat
    Last Post: 11-07-2010, 08:14 PM
  2. swim platform
    By blainb in forum Moomba Classifieds
    Last Post: 10-25-2005, 12:23 PM
  3. Swim Platform pad
    By weirdo0521 in forum Boat Owners
    Last Post: 06-19-2005, 04:56 PM
  4. Do folding Swim Platform brackets exist?
    By Rusten in forum General Chat
    Last Post: 03-31-2004, 11:27 PM
  5. Swim Platform brackets cracking gel coat on transom
    By dburroug in forum Service & Repair
    Last Post: 09-08-2003, 12:59 PM
