Yes, I meant when it really leaks, about once a year or so. I have tried different thickness of rope and find the factory spec stuff works best. I put around 75-100 hours on my boat per season. Most of the hours are skiing hours so it gets a workout.
Has anyone found a pump to drain the trans fluid? I have seen a few but never used anything more sophisticated than a turkey baster, which is painfully slow and doesn't get everything out. Thanks.... Allen
99 Outback LS
Thanks Ed! I will get one before Spring. Any ideas about pulling the prop and changing the prop bearings? Allen
99 Outback LS
Separate drive flange, remove prop, unbolt and lift engine, pull prop shaft out through cockpit, go under boat and remove/replace rubber-lined cutlass bearing. Reassemble, align shaft. Skiers Choice will fax you a sheet that describes alignment. Carefully noting the exact positions of motor mount bolts prior to disassembly will faciliate quicker alignment.
Not sure if you've got it all figured out yet but I'm verry well familiar with the noise you're talking about. It is verry hard to locate and it does seem to be coming from somewhere near the tranny. It especially accted up when pulling a heavy weight skier like myself. To solve the problem, I had the prop rebuilt (it had a few small dings) and the bearings re-packed. The dealer charged me about $250 to do it. Granted, I've only been out about 4 or 5 times since then but I've not heard a screech from it so I'm assuming it was the problem. Also, water leakage was much less after that![]()
Thanks for the info! We are going to change the shaft packing rope first and then test it out while skiing. If it still makes noise, I'll pull it and change the bearings. The prop is fine-no dings, so maybe we'll be okay with just the shaft packing.
Allen
99 Outback LS
I took out my 05XLV out for the first time (was only able to take it for a 2 minute cruse until it started to rain).
Last year, I heard a high pitch sound only when I would pull a skier out of the water but I did not hear it after that.
this time, I heard it when I accelerated (no pulling a skiier in the rain).
There are no dings in my prop. So maybe I need to have my bearings checked. What is the worst that will happen (reasonalbe bad situation) if it is a bearing problem? What bearings?
I was thinking of making a tape recording of the sound and taking it to my dealer for them to listen to. My full 1 year warentee end mid June.
Just a heads up on this problem. I found an extra piece of packing rope stuck in the cap around the shaft seal. It was only two inches long, but was enough to cause the problem This piece of rope was forcing the shaft to touch the ring when I cranked on the boat. I replaced the shaft rope and skied 165 times and had ZERO sounds from this area.
