    Feb 2003
    Maryville, TN
    Default Ground wire location
    Where exactly is the ground wire for the gas and oil gauge located on my 2001 Mobius? How do I make sure that they are secure. I'm having some problems with them and think the ground wires might have came loose.
    Aug 2002
    Maryville, Tn.
    Default Ground service
    What, exactly are the issues at hand? These gauges share the same ground. When lying under the dash (on your back), verify that the (blk) ground wire is secured to the left mounting post of the gauges, if not transfer those affected or all to the proper post. If you feel this is not an issue w/your boat, please set an appt. w/your dealer. Brian Raymond
    Feb 2003
    Maryville, TN
    The gas gauge reads 3/4 tank all the time, when i fill up and when there is less than half a tank. The oil gauge sits below zero and flickers back and forth. I checked the back of the gauges. None of the wires are mounted to the mounting posts of the gauges. The nearest dealer is 5 hours away so thats not an option.
    Aug 2002
    Maryville, Tn.
    Default Gauges
    Jon, when laying on your back looking up under the dash, verify the ground wires are all on the gauge gnd. post just above the left mounting brkt. stud(it will be connected to the gauge lite). These grounds run in series, and should be in the same pos. on oil, temp, fuel gauges, the volt gauge will be at 5 o'clock. keep me posted. Brian Raymond
    Feb 2003
    Maryville, TN
    both the fuel and oil gauge decided to work today. thanks.
  1. 08 LSV....is it throttle by wire or cable?
    By 2thdoc01 in forum Service & Repair
    Last Post: 04-24-2008, 05:38 PM
  2. Speaker Wire - What gauge?
    By cab13367 in forum General Chat
    Last Post: 04-21-2008, 02:05 AM
  3. Is it easy to put speaker wire in a new LSV
    By shulaj in forum General Chat
    Last Post: 07-10-2007, 05:30 PM
  4. 07 Mobius LSV 325 Drive by Wire?
    By Mritter in forum Service & Repair
    Last Post: 06-21-2007, 10:47 AM
  5. Trailer ground clearance-Need Help!
    By jdalebroux in forum General Chat
    Last Post: 05-18-2004, 12:32 AM
