Thread: Winterize if in heated storage?
09-20-2005, 09:06 AM #1Junior Member
- Nov 2004
- 25
I live in Michigan and will be keeping my boat in a heated storage facility this winter. Temperature will be +50 F the entire winter. Is there any reason to winterize the boat? I don't assume there would be any impact on my warranty?
Thanks for the help!
09-20-2005, 09:45 AM #2Member
- Jul 2005
- Birmingham
- 69
Replying to Topic 'Winterize if in heated storage?'
I wouldn't see a problem in it. Although I would still do the Stabil in the fuel. When you get it out of storage be sure to change all the fluids and the impeller. Do you have a good chance of losing power in the facility? My only concern would be if the power went out for an exteded amount of time and allowed the temperature to drop. Might not be a concern. I will be storing mine in the basement and I will just change the fluids and impeller before I drag it our for the summer.
09-20-2005, 11:52 AM #3Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Drain ALL the water! the rest is optional
I lost power at the lake for 10 days last winter.
SD2Naked red and white 2005 Moomba LSV
09-20-2005, 02:09 PM #4
I would think you'd want to fog the engine, also. Let's see.....change the oils, grease the rudder, fog the motor, drain the block, treat the gas............you must remember, you are still storing the craft for a long period of time. Rings will sieze, valves will stick, cables will get tight, etc, etc........I believe I'd winterize (put up for storage).
Hope this helps
ButtaLearn all you can today. Tomorrow you may need to know it!
09-20-2005, 11:41 PM #5Senior Member
- Jul 2003
- 340
Do the full winterization. Great reasons for it already stated. Also leaving water in the engine and exhaust heads will probably cause some extra corrosion.
New Boat Winterize
By beckman2713 in forum Service & RepairReplies: 47Last Post: 01-27-2008, 11:27 PM -
RUSH TO WINTERIZE?
By 04OUTBACK in forum General ChatReplies: 2Last Post: 01-05-2008, 01:43 AM -
When to Winterize?
By cpudoktr in forum Service & RepairReplies: 1Last Post: 11-02-2006, 08:39 PM -
Do you winterize your boat?
By TheBeeZ in forum General ChatReplies: 5Last Post: 10-13-2005, 09:39 PM -
winterize mufflers
By Yellowmobius in forum General ChatReplies: 0Last Post: 10-24-2003, 09:56 AM
