Results 1 to 10 of 13
Thread: Cover Straps
    Jan 2003
    Nashville
    Default Cover Straps
    When I pull my boat with the cover on, the straps for the cover rub against the hull and leave light black marks. Anyone have any suggestions for either preventing this from happening or an easy way to get the marks off my gel coat and decals. Also, while on the cleaning topic, I have heard some people talk about wiping their boat down with something called 303 after they take it out of the water. I looked at Walmart but did not see anything like that. Does anyone know where I can find that or another wipe on, wipe off cleaner for the hull to use after you take it out of the water. Thanks.
    Aug 2002
    Bismarck, NorthDakota
    I had the same problem with the straps I noticed them wearing the paint on my trailer. I went drastic, I had something similar on my old boat. I purchased some 1/2 inch bungee cord, 2 pieces of 22 foot lengths. I then add 5 or 6 hooks space accordingly on the inside of the trailer frame.
    When I put on my tarp I simply pull the bungee to the hooks.
    The first time you may have to adjust the lenghts to the tightenss you want.
    As for a spray on wipe off cleaner, I use Duckies. I think you can get it from Bart's.
    Bruce Fuerstenberg
    Jun 2002
    Lake Mayo NC
    303 is a vinyl cleaner, I have heard that alot of people use a 50/50 vinegar water solution on the hull. Last year I just washed mine w/ water and had massive water spotting on it this year, we cleaned with meguires hard water spot remover and then waxed. It looks better than when I got it! So the meguires stuff says it helps prevent the spots but I doubt it, so this year I'm gonna try the vinegar
    Jan 2003
    Minnesota and Wisconsin
    I have a relative who is a major boat enthusiast and runs a body shop (mainly for cars but also does boats).
    He says never trailer you boat with the cover on because the cover slap will burn your gel coat.
    After taking my Mobius on the road one day and getting the strap marks on the trailer I could see where he might be right.
    The thing here is that it is not just that straps that are doing the damage although it is the most obvious.
    I don't actually know what the net effect of 'burning' the gel coat is, but have taken his advice and always trailer without the cover.
    Granted this minimizes the utility of loading the boat up with lots of stuff. It also leaves the inside of the boat exposed when you stop. So I normally bring the cover and cover it if I am going to stop for any length of time.
    Aug 2002
    Maryville, Tn.
    Default Topless
    The basic boat covers are not designed for trailering boats and are difficult for mooring and boat lift ownres. The gel damage by trailering the boat, can be costly over time. I suggest for the above to look into a tonneau and cockpit cover, which snap on to the bow and snap on from the windshield to the transom. This is a nice option for cold weather skiers because you can close off only the bow area and drastically reduce wind. Please check w/your local dealer for pricing and availability. Brian Raymond
    Jan 2003
    Nashville
    Brian-
    My cover is the custom Moomba cover that came with the boat. I was under the impression that it was ok for trailering. But if it is just for storage, please let me know. Thanks.
    Aug 2002
    Maryville, Tn.
    Default Standard Cover
    Marty, The cover that comes with the boat is basically just a breathable storage cover when not in use. There is to much decal, gel, and other issues that occur with the straps and cover coming loose at towing speeds, if road debris and the elements of Mo' Nature are an issue when trailering(which I hope they are), the trailerable and storable cockpit and tonneau covers are a very wise investment. Brian Raymond
    Feb 2003
    Chicago
    Default Cockpit cover
    I agree with Brian. I had a cockpit cover made and installed for my 2001 Outback. While using the boat and trailering, the cover keeps the wind and debris out of the bow and cockpit. Tell the installer to put a few extra snaps on the front to prevent the cover from peeling back while trailering. It's worth the $200.
    Pman
    Nov 2002
    Default cover strap mark repair
    Is there a better way than another at getting rid of the marks left by towing. When the dealership salesman delivered the boat to me, he had it covered, so of course I thought it was ok to tow with it. Any ideas at removing the marks, that don't come off with washing. I have thought of trying wax or lightly compounding. Thanks for the help.
    Aug 2002
    Maryville, Tn.
    Default Strapless
    First, rub your finger down the damaged area, if no rigididy is felt, hand apply some Meguires cleaner/wax along the area in circular motions. This should eleviate your problem. If bumps are felt, they need to be lightly sanded with a 800-1200 grit sanding paper, buffed, glazed then waxed, with a carnauba based wax. Inform the dealer of your situation immediately, and have it repaired on your next service. Brian Raymond
  1. Boatmate tie-down straps
    By spyder in forum Sales & Information
    Last Post: 10-06-2007, 12:45 AM
  2. 06 lvs cover
    By davidl in forum General Chat
    Last Post: 03-19-2007, 06:57 PM
  3. Looking for cover
    By kamberra02 in forum Service & Repair
    Last Post: 06-08-2006, 01:49 PM
  4. Bow Cover
    By Will Watters in forum General Chat
    Last Post: 02-16-2005, 07:51 PM
  5. Towing New Mobius V no rear straps?!!!
    By in forum General Chat
    Last Post: 09-27-2002, 01:32 AM
