Results 1 to 6 of 6
Thread: RPM Gauge
    Apr 2003
    Michigan
    Default RPM Gauge
    I have a RPM Gauge numbered from 1 through 7 I need to know what the numbers stand for. For instance, does the 1 read 100 or 1000. I just bought a new boat this year and this is new to me. Where I bought the boat I should of asked. The dealer told me to get the boat up to 5500 I am not sur where that is on the gauge. I have a 50 HP 3 stroke Mercury. Thanks for your help......
    Danny
    Aug 2002
    Maryville, Tn.
    Default Tach, yes. Moomba, No
    Moomba boats have an analog gauge that read in increments of thosands(with marks for every 200 in between). The boats come with Indmar marinized V8 inboard Chevy motors, from carbureted to throttle body injection to multi-port injection 4 stroke motors. These motors vary in H.P. from 310-370H.P. The max. rpm. on these motors range from 4850-5400rpm. Double check on your make and model, keep me posted. Brian Raymond
    Apr 2003
    Michigan
    Default RPM Gauge
    The gauge I am talking about is an Teiefiex Morse Tach Gauge the numbers on the gauge is 0-7 I am not sure how to read the gauge. I just bought this boat which is a Sylvan 16 foot 1 inch 50 HP 3 stroke. Thank you for your help.
    Danny
    Aug 2002
    Maryville, Tn.
    Default Tach
    Danny, I wish I could be of more assistance, but I am not familiar with the gauge and boat that you own, Please check w/your local Sylvan dealer. Brian Raymond
    Apr 2003
    Michigan
    Default RPM Gauge
    Brian, Thank you for your help I will contact Sylvan.
    Danny
    Jan 2003
    Minnesota and Wisconsin
    Default RPM
    Personally I have never seen a tach represent RPM in anything but thousands of revolutions per minute.
    Teleflex is a pretty generic manufacturer and I would doubt that they would vary this standard.
    If you look closely at the gauge below the pivot point of the needle (or just above it) you will probably see a 'X 1000' or someting to that effect.
    http://bensonwdby.home.comcast.net/
  1. Ballast Gauge
    By Pike in forum General Chat
    Last Post: 04-17-2007, 08:52 PM
  2. RPM Gauge not working
    By 98outback in forum Service & Repair
    Last Post: 01-23-2007, 12:13 AM
  3. Gauge diameters
    By mvd in forum General Chat
    Last Post: 12-08-2006, 06:57 PM
  4. Temp Gauge Too Hot
    By in forum Service & Repair
    Last Post: 06-27-2006, 01:51 AM
  5. Gas Gauge
    By ward_knutson in forum Service & Repair
    Last Post: 09-13-2004, 01:15 AM
