Results 1 to 10 of 10
Thread: Winterizing
08-20-2005, 05:36 PM #1Junior Member
- Aug 2005
- 21
Winterizing
I have an Outback with a 5.7 L MPI motor. I was goiing to be winterizing the boat soon, but was soon how many steps were involved. Can anyone out there let me know what all would have to be done?
Thanks, Charles
08-20-2005, 06:30 PM #2Member
- Jun 2002
- Charlotte, NC
- 38
Replying to Topic 'Winterizing'
First off, download the Indmar Maintenance Manual from their web site. This will give you you exact instructons. There are several things and other please chime in if I missed something.
1. Fill your fuel tank up and add fuel stabalizer.
2. Remove drain plug to allow any extra water to drain.
3. Disconnect the quick disconnect hose behind the engine. (See Indmar Manual)
4. Disconnect the ingoing and outgoing hose to the impeller.
5. There is a bolt on both sides of the engine block (See indmar Manual). Drain the water from this.
6 Spray fog oil into the throttle body and on the spark plugs to prevent moisture.
7. Change the oil.
Hope this helps.Sloppy
2001 Moomba Outback LS w/tower, ballast and 320hp Indmar TBI. 4 blade prop, front and rear ballast
08-23-2005, 05:12 PM #3Junior Member
- Aug 2005
- 21
Thanks for the reply and the update on the Indamr site. Is there any need to run any antifreeze through the pick up or raw water pump or into the maifolds?
Thanks, Charles
08-23-2005, 05:12 PM #4Junior Member
- Aug 2005
- 21
Thanks, Charles
08-23-2005, 09:40 PM #5Member
- Jun 2002
- Charlotte, NC
- 38
Not for me, I live in North Carolina and have my boat only in freshwater lakes. If you live up North or have a closed cooling system it may differ. Check your manual.
Sloppy
10-11-2010, 01:42 PM #6Member
- May 2010
- 55
Is there a particular brand of fuel stabalizer that most agree on? I am new at this to and want to make sure I get the right stuff. Thanks!
10-11-2010, 01:52 PM #7
sta-bil.
can be had at any auto parts store.'06 Supra Launch 20SSV-gone but never forgotten
10-11-2010, 02:27 PM #8
Below is a link to a comprehensive, step by step, self-winterizing procedure. I think you will find it helpful.
https://forum.moomba.com/showthread.php?t=9877Al
10-11-2010, 02:44 PM #9
lol this is a 2005 post being brought back to life 5 years later
09 21v LAUNCH
99 Outback LS. Sold
Doug
10-11-2010, 05:21 PM #10
LOL! Doc, I totally missed that!
Al
DE-WINTERIZING?
By LSV04 in forum Service & RepairReplies: 23Last Post: 05-06-2012, 09:44 PM -
winterizing
By LSV04 in forum Service & RepairReplies: 1Last Post: 11-18-2007, 01:42 AM -
De-winterizing
By helix_rider in forum Service & RepairReplies: 5Last Post: 04-29-2007, 05:09 PM -
Winterizing
By mattjj23 in forum General ChatReplies: 1Last Post: 10-09-2006, 11:32 AM -
Winterizing
By in forum Service & RepairReplies: 0Last Post: 08-17-2005, 05:38 PM
