Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. #31
    Nov 2009
    How do you think it is going to do when you start to pull stuff off of it?
    -Mark
    "Hey you only live once"
  2. #32
    It's a solid chunk of aluminum so I'm not worried about strength. The only concern may be the angle of the rope back. Usually only pull the tube from it and at usual tubing speeds the bow rides a bit up. Used to attach my surf rope there but I can go with a longer one to run it off the tower instead.
    The new vinyl also has really flat stitching and no piping back there to keep it as smooth as possible - originally intended for the girls to not have pattern tattoos when they lay out but that should help with a slack rope getting caught up on anything too I'd imagine.
  3. #33
    May 2013
    I put a empty plastic mayonnaise jar over mine to spread out the pressure. works pretty go.
  4. #34
    Where the rope lays across the vinyl? You kinda lost me there.
  5. #35
    Portland Oregon
    Default Ski pylon solid? Thinking about shortening
    Tease! I see that diamond...
    -Jake
  6. #36
    May 2013
    over the pole then put the cover on
