    Oct 2010
    Winnipeg, Manitoba
    Default Water block plugs in 2006 supra
    I'm starting to second guess what we did when we winterized the motor prior to me bringing the boat home.
    The boat had been on the water for about 45 minutes prior to adding plumbing antifreeze, but we immediately added the antifreeze after getting back to the house. After a little thinking about this, we didn't run the motor up to temp and the antifreeze may not have made its way into the block due to a possible closed thermostat.
    At this stage it's impractical to perform this process again because the boat is in storage in closed quarters.
    As an alternative I believe I should be able to find the block plugs, remove them and that should be sufficient to drain any liquid, water or otherwise, from the block. The components on the other side of the thermostat should be fine, as we did witness antifreeze coming from the exhaust.
    Question at this point. Are there only 2 plugs, one on each side of the lower block about mid way on the engine? I'm assuming this is correct but hopefully someone can confirm my guess.
    Until I get an answer, I guess I'll have to find a manual on the supra site to see if it indicates where these plugs are.
    Damn, just came back from the storage facility after giving the trailer a little tlc. Replace the bearing seals on one side of the axles. The other side will have to wait until spring (no room to work)
    past---------------2003 Outback SOLD
    Ron
    what engine is in the boat? Ifs its the standard idmar 325 then yes only 2 mid way on the block
    Oct 2010
    Winnipeg, Manitoba
    325hp Indmar Assault 5.7 liter.
    Off to the storage facility tomorrow. Hope I don't have to get the guy to move a bunch of vehicles to get at my boat. Luckily I work with him, and he's got a heated shop right beside where the boat's being stored.
    If I pull the plugs and nothing comes out, be prepared to my obit due to stupidity.
    FWIW, there were 3 of us there winterizing and nobody thought to check the temp gauge.
    Ron
    Aug 2011
    Ugh..There's more to winterizing than just draining the block...You should read the how to..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Oct 2010
    Winnipeg, Manitoba
    Quote Originally Posted by parrothd View Post
    All the other stuff was done, fogging, fuel stabalization, etc. This part ended up being a concern, as none of the cooling system was drained. It was just displaced by plumbing antifreeze.
    Ron
